01-30-2018 01:39
01-30-2018 01:39
hey Fitbit, Ionic, what a piece of overpriced junk. cant believe i pain $450 for this piece of garbage.
it wont even stay turned on long enough to do the setup.
did reset, hard reset, factory reset, it wont even stay turned on long enough to complete the reset procedure.
any ideas Fitbit gurus.
this piece of rubbish hasnt worked properly since day one
01-24-2019 17:42
01-24-2019 17:42
@Mjszemi Welcome to the Fitbit Community.
I'm sorry to hear that your Fitbit Ionic won't stop blinking. Thanks for performing a factory reset before contacting us. I noticed that you contacted Customer Support. They should provide assistance to your case as soon as possible.
@respanol Thanks for your support.
Feel free to contact us at any time.
Best Answer02-02-2018 12:40
02-02-2018 12:40
Welcome to the Forums @Frank62!
Thanks for your patience to this matter, in order to further assist you I've gone ahead and created a case on your behalf. Soon you'll be getting an email with the next steps.
Keep me posted!
Best Answer02-02-2018 19:11
02-02-2018 19:11
Hi there. I have the same issue. Ionic worked ok for a month then it just started turning itself off. Have tried restarting, shutting down and have now done a factory reset, but it won’t stay on long enough to do setup.... 😞
02-02-2018
21:42
15:57
EdsonFitbit
02-02-2018
21:42
15:57
EdsonFitbit
exactly the same, the **ahem** thing wont stay on long enough to do anything with..... VERY frustrated
02-04-2018 21:07
02-04-2018 21:07
Hey Frank
have you had anything back from Fitbit??
21:26
16:00
EdsonFitbit
02-04-2018
21:26
16:00
EdsonFitbit
yes they responded quite promptly, they instructed a "factory reset" which i did as per their instructions, however it didnt make any difference, the unit will not stay on long enough to do Setup or Update wont even stay on long enough to be recognised by the App.
i have sent then this info today & await their reply..... this is all getting a bit thin for me, seems there is a fault with the unit & i am clearly not a technician. wonder how long before they offer to repair or replace???
Best Answer02-04-2018 23:23
02-04-2018 23:23
Hi Frank
Exactly the same as mine. Can you let me know what they come back to you please.
thanks
Best Answer02-06-2018 08:54
02-06-2018 08:54
Best Answer02-06-2018 10:38
02-06-2018 10:38
Yup, my Ionic just went dead...I've tried to reset, but it won't stay on. My phone can't sync to it because the Bluetooth can't connect. I charged it to 100% the night before and it stopped working this morning.
This is not looking very good.
Can you guys at Customer Support tell me how to wake it from the dead.
Thanks,
Ramone
Best Answer02-06-2018 12:02
02-06-2018 12:02
Best Answer02-06-2018 12:39
02-06-2018 12:39
Just went through customer support via chat and they had me reset to factory setting...it is working now. So, I'm back in business.
Best Answer02-07-2018 07:16
02-07-2018 07:16
Best Answer05-12-2018 12:23
05-12-2018 12:23
My Ionic has been doing the same thing but sometimes it'll just restart instead of completely shutting off. I've only had my Ionic for a few months and it's frustrating, especially when it happens in the middle of a workout..
05-12-2018 12:55
05-12-2018 12:55
Best Answer11-29-2018 07:27
11-29-2018 07:27
Hi all, my ionic just started doing this today. It was at all full charge and now it continuously turns off. I shut it down, reset it, hard reset, and now I am trying the factory reset but it won't stay on long enough to set up and or update. I have had the ionic for less than a year and have never had issues before.
11-29-2018 11:19
11-29-2018 11:19
My Ionic has been doing the same thing! Nothing helped! I bought it via Amazon and they gave me an offer to replace it. Therefore I have now a new Ionic wich is work properly.
11-29-2018 11:39
11-29-2018 11:39
Best Answer12-02-2018 16:40
12-02-2018 16:40
Hello everybody, I'm sorry to hear about the difficulties you experienced with your Fitbit Ionic.
@loukie @respanol Thank you for letting us know that your Fitbit device is now working fine.
@bastenn I noticed that you contacted Customer Support. I'm pretty sure they will do their best to provide assistance as soon as possible.
If you have any question, please let us know.
Best Answer12-15-2018 00:28
12-15-2018 00:28
With mine is happening the same. Did you have any luck solvent the problem?
Thanks
Best Answer12-17-2018 12:00
12-17-2018 12:00
@Gegmond Welcome to the Fitbit Community.
It seems that you contacted the Customer Support. Please check your inbox on the next days. They will let you know how to proceed.
Keep on stepping.
