10-17-2024
22:52
04:41
10-17-2024
22:52
04:41
My luxe has recently started going to a black screen even when there is still plenty of battery left the only way I can get it to come back on and start working again it's too attach it to the charger then the logo comes up and it's fine again. Everything else is functioning properly. Has anyone else had this problem ? Can this one be saved ? Do I just get a new one ?
10-27-2024 03:17
10-27-2024 03:17
10-27-2024 11:46
10-27-2024 11:46
10-27-2024 14:54
10-27-2024 14:54
I am having the same problem that you and others have mentioned. Frequent black screen even with medium battery. It won't charge above 75% and charging is super slow. I can restart only by plugging in to the charger. Time has been incorrect a few times in the past coulpe weeks and eventually resets. have tried everything that has been recommented on different sites. I also have the latest version of the software. I hope Fitbit is looking into this as I don't want to have to purchase another device -yet.
10-27-2024 15:02
10-27-2024 15:02
Same issue. Resetting and changing clock doesn’t work. Clearly this issue was caused by the firmware update. This is the second Fitbit I’ve had that has done this and the fix is always “buy a new one”. These devices shouldn’t fail within 2 years.
10-27-2024 15:38
10-27-2024 15:38
I was curious as to whether or not others with the black screen problem are not seeing their sleep & sleep score on their Luxe. I see it in the Fitbit app, but not on the device. I only noticed after someone else posted about having that issue.
10-27-2024 19:01
10-27-2024 19:01
10-27-2024 19:25
10-27-2024 19:25
Wow, lucky you!! Resetting my Luxe didn’t help. I still receive the black screen at least once daily.
10-28-2024 02:19
10-28-2024 02:19
Yea, that doesn’t work. Customer service said it’s not
fixable and oh so generously offered me 35% off a new one because it’s conveniently past warranty. This is the second one I’ve had now die within 2 years. These things are disposable garbage.
10-28-2024 02:59
10-28-2024 02:59
10-28-2024 23:11
10-28-2024 23:11
I just spent 3 hours in chat with Fitbit & they told me what they told you - not fixable but here’s a 35% discount. One of the thing he had me do was change the clock face- it installed it but got the black screen so had to be put on the charger to get the screen visible again. It just makes no sense that Luxe owners are all having this issue at the same time even though some of the Luxes are newer than others.
10-28-2024 23:13
10-28-2024 23:13
But your Luxe is still under warranty, right? So Fitbit should replace it since it is less than a year since you bought it.
10-29-2024 00:56
10-29-2024 00:56
Changing the clock face did nothing and incidentally when my first Fitbit I got in 2020, died in 2022, it was for the same reason (that was a charge 4 I think?). Same thing-screen stopped responding, resetting does nothing and was given the whole “try to change the clock face” thing, then the oh well, we can’t do anything here’s a discount on another item that will die prematurely as well. This luxe was from 2022 so it’s out of warranty.
There’s no reason these devices should be bricked after 2 years.
10-29-2024 08:32
10-29-2024 08:32
Hi
I'm having the same problem. Has been like this for a month or so. It is extremely frustrating especially when it happens during a walk or workout. In addition the battery life is erratic, display shows 100% to 75% in mere minutes or very low and back up to 90%+ when I simply connect. I now charge it every day. Customer service is of no help. Apparently they won't assist until I transfer my email to a google account. My Luxe is two years old; we should not have to replace every two years or get such poor customer service.
10-29-2024 10:34
10-29-2024 10:34
Wow, sorry to hear that you are having these issues. My battery charge goes wacko too. My luxe was replaced under warranty in August 2022, so I’m not covered under warranty any more either. They tell me this issue (the black non-responsive screen)is not fixable and offered me 35% coupon off a new purchase. I think I will just live with it the way it is. People are having some pairing and syncing problems with the sense and the charge fitbits, so I will have to think hard about what kind of fitness tracker is best for me. In the past I upgraded my Fitbit before they had issues. My luxe no longer displays sleep & sleep score either, although they are available on the app.
10-31-2024 06:18
10-31-2024 06:18
I’ve had this issue since the end of September. Non-responsive black screen that only turns responsive after being put on the charger.
i finally chatted with support and after 3 hours they told me it couldn’t be fixed and offered me a discount on a new device.
the next day I noticed there was an update for Fitbit app. I installed it and I have had 2 days without the black screen. AND my sleep and sleep score are showing up again on my Luxe instead of showing dashes.
if you haven’t installed the latest update Fitbit 4.29 (42929025), I suggest you try doing that. Hopefully it will resolve your issues too.
11-02-2024 01:47 - edited 11-02-2024 01:48
I have the same issue on my watch. I’ve just spoken to the helpline and been advised my watch does not have the latest firmware, and it isn’t available due to how old it is. It’s 2.5yrs old!
I was advised to replace it. Which I won’t be doing - or not with Fitbit!!!
when I questioned why it wasn’t available, there was no answer. The agent confirmed there was a new update, but that it just wasn’t available for my watch version - so being held back basically. It’s disgusting. I only purchased this watch 2.5yrs ago, conveniently problems started just outside of warranty…. What a coincidence!
11-02-2024 04:21
11-02-2024 04:21
Please can you tell me how I can get this update? I’ve looked on my iPhone as well as on the Fitbit app on my phone & even searched Safari. There doesn’t seem any button to click for updates. On my phone I always get a msg when updates are due & it says when your phone is connected for charging update will be installed. But here there is nothing. My watch is not that old. Bought in Jan2023 & from all the comments, they don’t bother with customer service.
also can anyone suggest a similar make with a slimline tracker watch? I don’t want to get another Fitbit
11-02-2024 04:25
11-02-2024 04:25
11-02-2024 04:26
11-02-2024 04:26
I agree. I loved my Fitbit Luxe, slim & small, as I have small wrists & can’t wear the square or round ones, but since last month I have had same problems. Starts up only when you connect to charger, battery shows high level, but when you wear it for a few hours, the screen goes black & you can’t even see the time, let alone steps or sleep score etc.
like you I don’t want another Fitbit having read all comments here. But would love it if someone can suggest another make but not very expensive. Thanks
11-02-2024 07:19
11-02-2024 07:19
Hi Js2222, thanks for the tip regarding the update 4.29. Unfortunately it did not work for me. Screen went black twice this morning already. This will be my last Fitbit.
