I am weighing myself every Monday morning and I am going to log my results each weigh for accountability and support. Please feel free to join in.
Start weigh 125.5 kg 14/12/2015
Now 124.2 kg 11/01/2015
Loss this week 200g
Loss to date 1.3kg
"Slow and steady wins the race"
@Move.It.Move.It- resting heart rate can be relatively stable in others and quite changeable in others. I use mine as a sign of overall health. If it's going down or staying down I'm not that concerned about it. However, recently, over a 30-day period it was trending up. For me that was a sign of over training, so it's driven me to a bit of a rest week (and may be followed by another).
I'm not quite sure how Fitbit determines your number for the day. I'm assuming that it takes a period of rest sometime early in the day. However, depending on how your day goes I've sometimes seen it go up or down.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
@A_Lurker wrote:USW- 407
CSW- 360 (Feb 2016)
PW - 251.6 (4/23/17)
CW - 251.4 (-0.2 lbs)
Progress: 108.6 lbs in 65 weeks = 1.67 lbs/week
UGW- No idea yet
So, a week of rest (of a sorts) and my resting rate was 67 this morning (from 77 a little over a week ago). I'm still doing 10,000 steps a day and a lightened 6-day strength training routine. I've also been attempted to eat close to maintenance. With the odd weather we've had I ended up with a migraine Thur-Sat, which wasn't fun either. I think another week of just consistent movement (and some gardening now that the risk of snow today is over) and I'll just let the food fall where it may. Starting the week after that I may go back to calorie counting for a little while, just to keep an eye on where I am.
USW- 407
CSW- 360 (Feb 2016)
PW - 251.4 (4/30/17)
CW - 251.2 (-0.2 lbs)
Progress: 108.8 lbs in 66 weeks = 1.65 lbs/week
UGW- No idea yet ![]()
@Move.It.Move.It -- congratulations on a good exhibition and on your new 20k badge! I have also noticed that extra activity sometime turns into weight gain. I know some folks claim exercise suppresses hunger but that has never been the case for me. And, of course, that junk food can taste pretty good! Back to the routine this week!
Scott | Baltimore MD
Starting 1-Jan-2017: weight 67.4 kg, BF 18.5%, fat mass: 12.5 kg
Previous 1-May-2017: weight 62.2 kg, BF 15.0%, fat mass: 9.3 kg
Current 8-May-2017: weight 62.0 kg, BF 15.0%, fat mass: 9.3 kg
Mini goal: BF 14.0%
Ultimate: BF 12.5% (e.g. weight: 64 kg, fat mass: 8 kg, lean mass: 56 kg)
Hardly any change since last week, which is kind of expected since I’m reporting TrendWeight numbers (= effect of inertia). This week will be challenging as I’ll be travelling abroad for business and I tend not to do well when staying at hotels, eating out, having plenty of food around and not being able to exercise as usual. Fortunately, it’s only four days, two of which will be mostly travelling (good things airlines no longer provide free food on short flights!).
Dominique | Finland
This Monday's numbers. Did a lot of home improvements over the weekend so lost a lot of water weight that I'm still catching up on. Hence the 3-pound loss (I assume).
Starting weight: ~241+ lbs
Current weight: 183.2 lbs
Last week's weight: 186.2 lbs
Weight lost this week: -3 lbs
Total weight lost: 57.8 lbs
Weight left to lose: 23.2 lbs
Mini-goal: <180 lbs
Goal weight: ~160
Here is my weekly weigh in:
SW 24/3/17 163lbs
31/3/17 162 -1
6/4/17 161 -1
14/4/17 160 -1
20/4/17 158 -2
27/4/17 157 -1
5/5/17 157.5 +0.5
Really upset to gain even this tiny bit this week and have totally fallen off the wagon since Friday. I was really 'good' all week and then discouraged by my gain and lost interest in even trying. This is an old pattern. It happens less than it used to--but here I am again with this old friend.Needing to get back on track again today. Felt too upset to post when I should have done on Friday (my regular day) and have gained more since then. Extra weight seems to come on so much easier than it comes off!!
Hey ho...I'm still tracking even when it's awful to confront what I am doing, and still moving 12000 steps a day minimum. So some positives. I am finding it hard this week though...
Start 265 lbs 09/27/2015
This Week 159.8 05/08/2017
Last week 157.8 05/01/2017
Maintenance mode
Loss Range 105 lbs +/- 5 lbs
I had a three hour sleep due to an allergy attack last night so I worked the minimum and didn't work out this morning so I am not surprised to be logging higher. I looked back today and realized it's been just over a year since I quit logging what I eat. That means for over a year I have been eating "intuitively" and maintaining and even continuing to lose weight. That is a huge victory for me. I trusted myself to eat what I felt I needed and see what the results are and so far I'm crushing it. I'd be lying if I said I wasn't proud.
@Dominique, I stopped by a gym last week and they had one of those fancy electronic BMI testers (she said it was the most accurate thing other than submersion). She measured me at 9.8% so that seems a lot more realistic and still a phenomenal number. I estimate that I started weight loss around 40% BF so I am blown away by this.
Well, it's snowing here (Ottawa) in May, which is simply not right. I still managed to run on the treadmill this morning after taking dogs for a walk. Looking forward to my FB that I suspect I'll be able to unwrap mother's day!!!
Re. Weight, I seem to have mastered the maintenance. Clearly I have to step things up a notch this week to see some real progress. My goodness this takes a long time, but I have to remind myself that if I wasn't doing this, I may be UP from the start, so could be worse.
Reading everyones' posts are very inspiring. Thank you!!!!
SW - 193.8 - March 20 First day of spring!
192.7 - March 27th, one step in the right direction.
192.8 - April 5th. Same... close enough!
191.8 - April 10th Down, yay!!!!
193.1 April 18th boo...
192.7 April 26th OOOKAY
192 May 1st Keep going...
CW - 191.7 May 8th Slow...
Total down 2 lbs.
MiniGW - 189
UGW - 160
My MIL turned 96 last week, which meant a meal out. This past weekend we had a family reunion. That side of the family has Indonesian roots, which means FOOD and plenty of it. I did not over eat, but did drink more than usual. Yesterday I weighed 77.7 still, but today is weigh in day and I show a gain.
Onwards and downwards!!
SW January 31- 79.8
March 28- 78.5
April 4-78.6
April 11- 77.9
April 19- 78
April 26- 77.8
May 2- 77.7
May 9- 78.1
GW- 70 kilos
@mew1967 wrote:
I went down 3 pounds the other day and today is back up 3 pounds...I guess I am even oh well
@mew1967: these fluctuations are typically due to water weight. You may want to try using TrendWeight (just log your weigh-ins in Fitbit, then link your Fitbit account to TrendWeight). It’s really handy for eliminating the impact of such fluctuations. See the link in my signature. It’s totally free, btw.
Dominique | Finland
@tamado wrote:@Dominique, I stopped by a gym last week and they had one of those fancy electronic BMI testers (she said it was the most accurate thing other than submersion). She measured me at 9.8% so that seems a lot more realistic and still a phenomenal number. I estimate that I started weight loss around 40% BF so I am blown away by this.
@tamado: you probably mean BF tester, not BMI (you don’t need a tester to determine body mass index). Here are two sample pictures (source1 and source2😞
and:
I don’t know if I’ll ever get there, but if I do, that would probably take me another 3-4 years. Congrats if you’ve managed to do it, especially from a starting point of 40%!
Dominique | Finland
Guess I'll start weighing in to keep me motivated.
starting weight (pre Fitbit) Nov 14 2016;
123kg
starting weight (Fitbit) March 02 2017;
97.7kg
current weight; 89.3kg
BF; 43.2%
target Weight; 70kg (then I'll see
there)
weigh in on days are Monday for me but I do jump on my aria scale every morning
@Pamala it sounds like you did really well overall, with eating well and drinking a little more than usual. A small gain which will not take long to turn around. I know how discouraging a gain can be, but hang in there. You are motivated and want to succeed. So many on this group are so inspiring with what they are achieving and I"m sure you and I can do it too!
Start: 253 lbs
Last Week: 148.6 lbs
This Week: 146.0 lbs
Change: -2.6 lbs
Total Loss: - 107 lbs
Goal : 125
Mini Goal: 141 lbs - I will be considered "normal weight" according to BMI charts
Not surprisingly, lost a bit more this week. Makes up for the 0.5 pound loss last week. Weight loss is most certainly non-linear!
Ran my first trail 5k yesterday. That thing kicked my butt! Trail running is very different from road running. The steep climbs and descents, dodging pine cones and twigs, narrow paths and very few flat areas make for a very challenging run! My goal was to not come in last, which I accomplished (there were seven people behind me). I am still very slow, but I'm determined! Although it wasn't a goal, since road running and trail running are so different, I was 1.5 minutes faster yesterday than during my very flat road 5k race in March. So, looks like I'm improving slowly, but surely.
I already signed up for three more trail races this summer. The next one is coming up in less than a month in June. I can't wait!
Starting weight:
1st Jan 2017 142kg (313lbs)
10th Mar 2017 126.9kg (280lbs)
16th Mar 2017 126.3kg (278.5lbs)
23rd Mar 2017 123.9kg (273lbs)
1st Apr 2017 123.3kg (272lbs)
10th Apr 2017 122.5kg (270lbs)
17th Apr 2017 120.9kg (266.5lbs)
25th Apr 2017 120.0kg (264.5lbs)
10th May 2017 118.8kg (262lbs)
Target weight:
100kg (220lbs)
A bit of a gap in posting, I went on holiday for a week. I ate really well, but also exercised like crazy (almost 150k steps in the week!).
It seems that I've joined the 50lbs loss gang!
I'm moving so much better. 9 mile run in 90 mins this week. No aches or pains next day. The lard on my gut is finally looking like it's melting (slowly!) away.
All is good! Hope everyone else is feeling equally focused and satisfied!
@AuroraKat wrote:My goal was to not come in last, which I accomplished...
Even if you're the last runner to finish, you're not last.
Even if you get injured after 100 yards and decide to stop, you're not last.
DNF on a race card trumps DNS!
"Last" is a title reserved for those who could've done something but chose instead to stay in bed. Or sat in front of the idiot lantern stuffing Pringles into their face. Or laughed at the person coming last even though they didn't have the moral fibre to even try.
I'm a fat runner. I take pride in that title for two reasons. Firstly, I've acknowledged that I'm fat. That was the first step in tackling the problem. Secondly, even a fat, slow, panting runner is a runner.
With your success, you can dispense with the word fat. That makes you a runner!
Well done! You inspire me.
