04-30-2019
14:02
11:08
04-30-2019
14:02
11:08
I have only wonderful things to say about the new firmware update, but just now, I see something I haven't seen before on my tracker. A big battery with a circle and an exclamation point in the middle. My battery is at 18%. I usually let it go down to 10% or so and then charge it.
Is this the tracker telling me to recharge my battery or is something wrong?
04-30-2019 16:35
04-30-2019 16:35
I’m having the same issue!
Best Answer05-01-2019 04:17
05-01-2019 04:17
I have the same problem. Fitbit won't charge at all now and am working with Customer Service to resolve the issue.
Best Answer05-01-2019 04:21 - edited 05-01-2019 04:23
Actually, I assumed FitBit was telling me to charge my battery, so I put it in the charger and now it's fine. It charged and works perfectly well. Don't know if this will last though...
Please let me know what Customer Service says. Thank you!
Best Answer05-01-2019 04:41
05-01-2019 04:41
Best Answer05-01-2019 04:45
05-01-2019 04:45
Best Answer05-01-2019 06:20
05-01-2019 06:20
This is exactly what they are doing to correct my issue.. the error appeared on my fitbit while I was wearing it, it didn't have anything to do with the cord or charging. It has to be the update they did recently.
Best Answer05-01-2019 06:26
05-01-2019 06:26
Best Answer05-01-2019 06:31
05-01-2019 06:31
You know what's funny.. that is the EXACT percentage that mine said when I tried to charge it after the error but if I could get to another screen on my fitbit the percentage was different. I wonder if the 18% is part of the error.
Best Answer05-01-2019 06:36
05-01-2019 06:36
Best Answer05-06-2019 10:42
05-06-2019 10:42
I am having the same problem & also at 18%. A successful restart did not change the "message."
Best Answer05-06-2019 10:58
05-06-2019 10:58
@Zelda410 I checked with the team this is expected behavior, it indicates that you have 1 day of battery life yet. You should be able to dismiss it by pressing the button.
@psjcal Did you try pressing the button on the left-hand side, did this dismiss it?
Actively managing your weight? Find accountability buddies on the Manage Weight board
05-06-2019 11:03
05-06-2019 11:03
None of that helped me. Customer Service is sending me a new charge cord to see if that will help correct the issue.
11:03
11:26
KateFitbit
05-06-2019
11:03
11:26
KateFitbit
A few days ago, I got this big battery with an exclamaiton point. It was at 18%. I put it on the charger and it was OK
Now it just happened again. Before the update, I could bring it down to below 10%, which meant I had another night with the battery and could charge it in the early morning when I am not as busy.
What is that big battery all about and, if it's a warning to recharge, can it be bypassed or put at a lower percantage?
It just happened to me again - at exactly 18%. Putting it on the chargr
seems to be working. It's still on it.
Thank you for that. It just happened to me again and I put it on the
charger.
Next time, I will know what it means and push the button. Will give you
feedback in a few day because now it's almost all charged.
moderator edit: merged several posts
Help!
11:33
09:04
05-06-2019
11:33
09:04
@Karlarw are you still seeing the battery/exclamation mark? Our tools indicate you are above 18% battery.
@Zelda410 I merged your posts together to avoid crossposting. Tip: if you want to add more information you can edit your post by tapping the three dots in the corner. This warning indicates you have approximately 1 day of battery life left. You can dismiss it, but will see another warning when it goes below 10%. Are you saying that you are not able to dismiss it?
Best Answer05-06-2019 11:39
05-06-2019 11:39
05-06-2019 11:44
05-06-2019 11:44
I managed to get my fitbit to charge a little so the battery pic went away. I had to find the perfect position for it and make sure it didn't move while being plugged in to charge even a little. I'm hoping that getting a new charger will fix it.
Best Answer05-06-2019 12:20 - edited 05-06-2019 12:23
@Zelda410 , @Karlarw thanks for your feedback. I'm letting my Charge 3 go down to 18% to review the experience. But as mentioned, this is anticipated. It can be dismissed by squeezing the button.
Best Answer05-06-2019 12:25
05-06-2019 12:25
05-06-2019 14:02
05-06-2019 14:02
I did indeed press the button -- no go -- however a charge worked. This does seem to be an 18% issue & in the past I was able to go another 24 hrs when it got to 20% so this is NOT convenient.
