07-02-2018
00:29
18:22
07-02-2018
00:29
18:22
My display is showing zig zag / wavy lines. A few hours ago it was fine and now it's not. Any suggestions? It's not been worn in water....only occasional splashes from hand washing etc.
TIA
Emma
07-02-2018
00:31
08:56
AlvaroFitbit
07-02-2018
00:31
08:56
AlvaroFitbit
First thing to try when a fitbit misbehaves is a restart using the following procedure:
It does no harm and can sort out all sorts of issues. You might need to give it a few tries though as it's known to not always work.
07-17-2018 08:58
07-17-2018 08:58
@Emma-Christmas Welcome! Thanks for being part of our Community! Sorry to hear about your damaged Charge 2 screen. The restart is what we suggest for this issue so I wanted to know if @SteveH's instructions helped you? Does the issue persist on your tracker?
I look forward to your reply!
Best Answer02-15-2019 16:01
02-15-2019 16:01
Hello...
I also have the same problems.. But i have done try the step guide.. But it still not function.. Any suggestions form you to solved the problem ?
02-15-2019 16:06
02-15-2019 16:06
Hello @AlvaroFitbit
I have same problem with @Emma-Christmas I have try the guid from @SteveH It not function with my fitbit charge 2. .. Do you have any suggestions to solved my problem?
02-19-2019 08:12
02-19-2019 08:12
@Jalilah Welcome! It's great to see you around! Sorry to hear that your Charge 2 display isn't working. thank you for following the suggestions in my previous post. Since the issue persist the best thing is to let our support team know. You will get an email so they can further assist you.
Keep me posted!
