09-26-2016
14:31
10:26
09-26-2016
14:31
10:26
Hello! I love my Charge HR and am thinking of upgrading. My biggest issue I have with my current tracker is having to put in on my shoe during spin class to get my steps to count (making the heart rate part not usable then).
With the Charge 2 - will I still have to do that to get my steps to count? Or do the different workout fuctions accurately track everything? On average I get about 4,000 steps in a 45min class.
Thanks!
01-17-2017 13:58
01-17-2017 13:58
How can I track either my stationary bike workout or road bike workout on my Charge 2?
Best Answer01-17-2017 14:01
01-17-2017 14:01
How do I set my charge 2 to bike?
Best Answer01-25-2017 13:57
01-25-2017 13:57
Just curious. Why count steps when you are spinning? Spinning is not a step based activity. Neither is riding a bike. So why count steps at all for the activity?
01-25-2017 16:32
01-25-2017 16:32
01-25-2017 16:50
01-25-2017 16:50
Best Answer01-25-2017 22:48
01-25-2017 22:48
@Kermit0276 wrote:
Hi! I agree that spinning is not stepping, but it's still movement none the less. When I put my Fitbit on Spinning, it counts my heart rate and does not count repetitions (steps). If I tie it to my shoe I get the step count, but I lose out on tracking my heart rate. I guess I just wanted it to track each rotation as a step!
I hope that answers your question.
Sent from my iPhone
Thanks for the insight. 🙂
Acctually it does count your steps. It just does it poorly ( like it does for all non-step based activities).
The steps are not visible on your excercise row, as it's not step based, but they are added to your daily total.
There is a couple of of features requested than wants to changing stuff around. Please check them out and vote.
Note: I think the last one could be up your ally. It's aimed at making it optional to keep/remove steps as a default.
https://community.fitbit.com/t5/Feature-Suggestions/When-making-Category-Bike-deduct-steps-form-dail...
https://community.fitbit.com/t5/Feature-Suggestions/Eliminate-step-count-when-Surge-is-in-bike-mode/...
https://community.fitbit.com/t5/Feature-Suggestions/Option-to-remove-steps-earned-when-cycling/idi-p...
https://community.fitbit.com/t5/Feature-Suggestions/Activities-Eliminate-steps-when-manually-logging...
https://community.fitbit.com/t5/Feature-Suggestions/KEEP-Steps-while-CYCLING/idi-p/906635
Best Answer01-26-2017 01:41 - edited 01-26-2017 01:42
@Blueberryrock for spinning class use the spinning mode on the Charge2
For Biking you have three options, let Fitbit auto detect, its not as accurate and no miles, or use the Bike mode and connected GPS with the phone, or Bike mode without the phone.
@Kermit0276 Fitbit uses calories for the common unit, putting the tracker on the leg might give steps, but fitbit ignores these steps in figuring the caloric burn for bike and spinning, these steps are usuwlly caused by bumps in the road.. Without the heart rate the calories would most likely be off.
@ValerieAnne did you do your own investigation, or assume that since steps are added to a walk or a run, they also must he added to spinning.
I just used the tools at my disposal, the Fitbit app, manually added spinning, the only thing it records is time and calories, no input for miles. Then again your sitting still.
02-03-2017 09:53
02-03-2017 09:53
Thanks for the info on finding the Spin option on y Fitbit Charge2. Would you wear the Fitbit on your wrist or ankle while using the Spin option?
Best Answer02-03-2017 10:42
02-03-2017 10:42
It is completely possible to track Biking with connected gps or Spinning (without GPS) on Charge 2. If you don't see these options on your Charge 2, you can add them by following the instructions listed here.
@GrandmaDebbi I'd recommend wearing it on your wrist, that way you can track your heart rate and get a more accurate calorie burn for your exercise. I'd also recommend these three tips to ensure that you get the most accurate heart rate reading during your workouts.
02-03-2017 18:58
02-03-2017 18:58
Thank you! 🙂
Best Answer02-06-2017 12:48
02-06-2017 12:48
I would agree with this, why count steps for spinning. I wish it tracked miles, but our bikes at our gym do that for us.
Best Answer04-24-2017 08:11
04-24-2017 08:11
Hi! I spin regularly and chose the Charge 2 for heart rate and sports choices. I conducted an experiment with one of my classmates yesterday in which I wore mine and put it on spinning mode and she attached hers to her shoe. We compared in the end and she got 1,000 more steps! I expected her to have more but was shocked by how much difference it made. Obviously we aren't the same person, but we both are experienced and kept pace and that's a huge difference. I still prefer the heart rate and cardio zone info but good to know. I may switch my main goal to calories or active minutes.
04-24-2017 17:34
04-24-2017 17:34
I did the same thing when I teach spin...wore it on my wrist and ankle; used the spinning setting compared to the workout setting compared to setting no activity at all and I got many more steps wearing the Charge 2 on my ankle and not setting an activity! I know we are supposed to wear the tracker on our wrist and it's not great for biking, but I had to run a few tests! ![]()
Best Answer03-03-2019 05:04
03-03-2019 05:04
Very helpful. Thank you. I will use the spinning option today!
Best Answer06-12-2019 23:04 - edited 06-17-2019 07:52
I put my tracker in my sock when I use a stationary bike. Counts my steps and heart rate
Best Answer06-15-2019 16:00
06-15-2019 16:00
Interesting @Jokerjones how many steps did walk while riding the bike?
