06-28-2017
06:35
13:20
AndreaFitbit
06-28-2017
06:35
13:20
AndreaFitbit
My Charge2 has been working awesome tracking my sleep. Suddenly I have not been able to see the daily sleep recordings. I've tried syncing my Charge2 several times but getting everything except the sleep recordings so I know it is not my Bluetooth. It last recorded 2 days ago. I love the sleep feature on my Charge2 and am very disappointed that it currently is not working. Any suggestions as to what I can do to fix this problem?
Hi,
I have a fitbit Alta and I'm not sure which button you are referring to. Can you clarify?
Cheers
Best AnswerWhy don't my sleep data :last_quarter_moon_face: show on a fitbit watch i reset it and still not showing...it showed once long only once then stopped again
Best AnswerMy question exactly. What button? The side button on the tracker is engaged in charging. So pressing that while charging is not an option. Does one take it out of the charger?
Best AnswerPlease restart your tracker by doing the following: Plug the charging cable to your computer or UL certified wall adapter. Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely. Your tracker should start charging.
Regards,
Will
