12-20-2018
21:16
18:22
12-20-2018
21:16
18:22
I just received my 2nd replacement Fitbit charge 2, the first one
worked but only for a few months than stopped syncing and sending notifications to me. Than I was sent a replacement again and it will restart and vibrate like it’s charging but no battery shows up just the set up link that takes you to the app. It won’t sync or set up my replacement like it should! I keep having these problems and it’s rather annoying having to keep going through this process again and again...
12-31-2018 04:07
12-31-2018 04:07
05:25
03:24
AlvaroFitbit
12-31-2018
05:25
03:24
AlvaroFitbit
Yes I got that message 2 weeks ago as well! I have other things to handle
right now than keep checking for emails that don’t seem to be coming!
Moderator edit: removed personal information
01-07-2019 08:14
01-07-2019 08:14
Hi everyone. Sorry to hear that your tracker isn't charging nor setting up. For charging issues try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Regarding the setup you can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. Please be aware that Android users are having issues syncing with Android 9 (Pie), you can check this thread to keep up to date with this.
Let me know how it goes!
Best Answer01-07-2019 09:28
01-07-2019 09:28
01-07-2019 13:35
01-07-2019 13:35
I have a iPhone and I am awaiting a reply email had been waiting for a few weeks finally sent one to your help center and nothing yet! Not very pleased! Wonder if it all replaced ones and if new ones work better...
01-07-2019 14:21
01-07-2019 14:21
Yep, having the same problem. Got the tracker today (replacement) and not pairing with anything. Might go for a Garmin. Fitbit seem to be a bit of a waste of money.
01-12-2019 15:43
01-12-2019 15:43
Same problem and called Fitbit. They said they are aware of the problem and they are working on it, but I sincerely believe they have no intention of fixing the problem with an older model. They want you to bur the Charge 3. Not happening here! I am fed up and going to an Apple product.
01-12-2019 19:46
01-12-2019 19:46
Same problem, 3rd round (three replacements of a charge 2 that does not sync with any device, many discussions with customer service). Fitbit simply does not care honoring their warranty.
01-12-2019 19:53
01-12-2019 19:53
Am I going to get a reply in my email from your department it’s been 2 weeks since I have got any emails from anyone in Fitbit. I fee like I have been ignored with this situation....
01-13-2019 01:16
01-13-2019 01:16
I think it’s time to stop posting on here and bombard their FB and twitter accounts. Search Fitbit support and post on their timelines.
We are being fobbed off with rubbish products and laughable support.
Keep,plugging away. They think we will just get fed up and forget it but they are wrong!
01-13-2019 04:49
01-13-2019 04:49
01-13-2019 05:56
01-13-2019 05:56
Best Answer01-13-2019 08:28
01-13-2019 08:28
Me too. I’ve given the 48 hours to sort it. After that I’m calling Trading Standards.
Best Answer01-13-2019 08:30
01-13-2019 08:30
01-13-2019 09:19
01-13-2019 09:19
01-13-2019 09:20
01-13-2019 09:20
Best Answer01-13-2019 09:58
01-13-2019 09:58
It’s a UK consumer protection service that we can contact when companies sell us rubbish.
Best Answer01-13-2019 10:00
01-13-2019 10:00
01-16-2019 00:36
01-16-2019 00:36
Success at last. Got my new tracker, it didn’t look to be charging when I attached it to the charger but then 4 numbers appeared which meant it had synced to my iPhone. At last!
01-16-2019 07:08
01-16-2019 07:08
