05-22-2020
15:15
09:40
05-22-2020
15:15
09:40
Have not been able to restart my Charge 2. Changed the clock face and now locked.
05-25-2020
12:19
09:10
AlvaroFitbit
05-25-2020
12:19
09:10
AlvaroFitbit
How to insert pictures:
1. At the top of your message, there will be all sorts of different icons listed.
2. Find the camera icon at the top and select.
3. Select choose files
4. To find your recent pictures you have taken, select recent.
5. Select which photo or photos of your charge 2 you would like to show.
6. Once your photos are selected, select the button that says ¨open¨
7. Once you have selected ¨open¨ your picture or pictures may take a moment to upload. But when they are all done, somewhere on your screen there will be a blue colored ¨Done¨ button. You will select that a then your picture(s) should be posted with your message.
Note: The instructions may not be the same, or look the same because of which device you are using to communicate with me right now. May I know what device you are using at the moment to contact me?
12:45
09:10
AlvaroFitbit
05-25-2020
12:45
09:10
AlvaroFitbit
Dear M. Son, I am replying via my Apple Desktop.
Herewith the photo of my Fitbit taken a few seconds ago.
13:07
09:11
AlvaroFitbit
05-25-2020
13:07
09:11
AlvaroFitbit
Alright great! Nice, you got the pictures working. Ok, I've done some research on your problem. Some people have had the same problem as well. The only key that comes up for fixing your locked fitbit charge 2 display is...:
¨You can try cleaning the tracker's contacts with a toothpick or toothbrush then use cotton with rubbing alcohol. After this fully charge your tracker by plugging it for a couple of hours and restart your tracker a few times by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.¨
This was marked as the best answer I have seen so far. So, please try this again.
Let me know how it goes! If it doesn't work I will consider something else and I will also consider finding some help from a fitbit moderator. I will look in to finding one for you. And I will think of some other things to solve the problem. It's kind of a lot to process and put together. I'm trying to put it all together. We will work it out.
Best Answer05-25-2020 13:28
05-25-2020 13:28
Thank you M. Son. I have followed your instructions and cleaned the contacts.
I have plugged the tracker into its charger and made sure that it snapped securely.
I pressed the Tracker's button for 12 seconds - the "frozen" screen showing 12:40 23May came on, but not the firmware version.
Please excuse me as I have to care for my sick wife. I will log on again tomorrow.
Thank you, Malcolm
13:45
09:10
AlvaroFitbit
05-25-2020
13:45
09:10
AlvaroFitbit
Good, ok. Ah, I've seen this exact problem somewhere on this website someone had or has. I will do some more investigating on that. Oh ok, well you're definitely excused. I hope your ill wife is not too sick, and I hope that the incident does not worsen and your wife gets better soon. And your welcome, anytime. Talk to you soon!
13:53
09:09
AlvaroFitbit
05-26-2020
13:53
09:09
AlvaroFitbit
Thank you M.Son. My wife is recovering from an undiagnosed blood disorder and was in hospital for 14 weeks until late February 2020. Now off to bed and looking forward to hearing about the potential solution to my Fitbit problem. Regards, Malcolm
09:09
07:14
05-28-2020
09:09
07:14
@Mamacorr Welcome to the Community. Sorry for the delay in my reply.
Let me help you with your Charge 2 screen being stuck and thank you for restarting and troubleshooting the issue following @M.Son suggestions. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Best Answer05-28-2020 13:30
05-28-2020 13:30
Dear AlvaroFitbit. Amazingly, at 11:40 today, without any action taken by me, my Fitbit Charge 2 defrosted and came back to life. I have taken 4,833 steps and all is OK. I am delighted.
Thank you to the Fitbit Connunity
Best Answer05-28-2020 13:46
05-28-2020 13:46
Wonderful!
Best Answer05-28-2020 13:49
05-28-2020 13:49
I'm glad to hear that your charge 2 is back to normal! Now you can track your sleep and everything again. Do you have any other questions or comments?
Best Answer05-29-2020 00:21
05-29-2020 00:21
Thank you M. Son. Your diligence in trying to sort out my problem is appreciated. Regards, Malcolm
Best Answer05-29-2020 11:13
05-29-2020 11:13
No problem, I'm glad to help!
