09-03-2020
07:45
09:08
09-03-2020
07:45
09:08
I have even disabled the app and re installed the app....I can not get it to sync since Aug 20
10-14-2020 16:59
10-14-2020 16:59
Same here. Last sync October 10. I unpaired and now it will not pair
10-15-2020 03:09 - last edited on 01-21-2021 19:34 by LiliyaFitbit
Well it is going better now. I have to recharge once at 30% and fix it harder on my wrist.
Best Answer10-15-2020 05:50
10-15-2020 05:50
Same here, nothing is try is working, my Aria 2 scales sync fine. I can't seem to get a straight answer from fitbit just the same cut and paste follow these instructions.
JP
Best Answer10-15-2020 06:07
10-15-2020 06:07
01-17-2021 16:07
01-17-2021 16:07
Hey Aribana,
Did you ever get a resolution for the syncing probs? I had some health issues this Fall & hadn't used the App/website until recently, when I discovered ALL MY DATA since that magic date of AUG 23 is gone!
I was regularly verifying my Charge 2 was connected because of past Bluetooth drops, but foolishly thought being connected meant my data was syncing. Anyway, I figured I'd be your 44th Reply before investigating further.
Thanks, Cheryl
Best Answer01-19-2021 06:53
01-19-2021 06:53
Best Answer01-19-2021 10:48
01-19-2021 10:48
Thx, Brian. I'll give that a try.
