10-15-2018
23:28
15:06
10-15-2018
23:28
15:06
Has anyone had any issues with the charge 3 battery. My charge 3 is a week old and needed a charge Sunday night. I charged it over night and in the morning it was showing 100%, I wore it all day Monday however early hours of this morning (Tuesday) by watch was dead. I’ve had to hold the buttons for 8 seconds for it to come on however it ran out of battery? I synced my watch and phone before bed and there was over 80% battery. Has anyone’s else done this?
08-28-2020 05:49
08-28-2020 05:49
Leahstormborn99, when this happened to my fitbit, 16 months in, and all the troubleshooting steps didn't work....they offered me 25% off items on their website. they said because it was over a year old and hence out of warranty. For what they cost, they should last longer. I won't buy another fitbit product. It was my 3rd. I was also in the wellness field and had often suggested them to people-. Yours is less than a year old. you might try calling them before the year is up and ask for a replacement. good luck!
Best Answer09-03-2020 10:57
09-03-2020 10:57
@Leahstormborn99 @sanmar Thanks for stopping by!
Sorry to hear that your tracker isn't holding a charge. As @sanmar mentioned since the issue persists the next step is reaching out to our Support team for assistance. I noticed that you already have a ticket with them so keep working with the team to find a solution.
Let me know how it goes.
Best Answer10-01-2020 14:03
10-01-2020 14:03
I used to love my fitbit but lately the charge only lasts 3 hours.
The info page said to go to settings, find reboot and select that.
My settings do not offer a reboot option.
Any suggestions?
Best Answer10-01-2020 14:23
10-01-2020 14:23
But how do I restart my device if I can't shut it down?
Best Answer10-01-2020 17:38
10-01-2020 17:38
Parece ser que muchos tenemos el mismo problema, en mi caso, recién cumplido el año, comenzo a fallar la batería... que mala calidad del dispositivo, esperaba más de fitbit. En lo personal creo que buscare de otra marca, porque la respuesta que me dan es que compre uno nuevo...
Best Answer10-01-2020 17:40
10-01-2020 17:40
Exacto, para mi fue un fiasco... la batería del charge 3 da problemas y falla muy rápido... que mala calidad
Best Answer10-01-2020 17:43
10-01-2020 17:43
La misma decepción me ocurrió a mi... la batería del charge 3 da muchos problemas, llega un punto en que ya no carga. De igual forma creo que no volveré a comprar un producto fitbit
Best Answer10-01-2020 17:46
10-01-2020 17:46
A mi me paso muy similar me duró cerca de un año, aunque en los últimos meses se descargaba con mayor facilidad, pero luego del año, ya no cargó .. decepción total del charge 3, deberían mejorar la calidad.
Best Answer10-01-2020 17:47
10-01-2020 17:47
Ya veras que pronto, no durará ni un dia la batería y luego horas... finalmente un par de minutos. Decepción total del producto.
10-01-2020 18:24
10-01-2020 18:24
I have. It started right after the firmware update.
Best Answer10-02-2020 12:29
10-02-2020 12:29
How do you actually contact support I’m having no luck. Posted a reply yesterday that I can find. Have tried all of the suggestions. Since update it won’t last 4 hours. It syncs. It doesn’t last. This is my 2nd Fitbit. First died and tried the charge 3. If it can be remedied it will be my last Fitbit. Help appreciated.
