03-22-2019
11:38
11:22
03-22-2019
11:38
11:22
My Charge 3 (a gift) is less than three months. The display will come on but most times is faded and difficult to impossible to see. It is NOT a charging issue. How do I get full display all the time?
03-23-2019
05:09
10:29
03-23-2019
05:09
10:29
A warm welcome to the Community @Lilamom94.
I am sorry to hear that your tracker's display is fading, have you tried the restart process? If you haven't, I recommend taking a look at the help article How do I restart my Fitbit device? and follow the instructions provided there.
Let me know the outcome. ![]()
05:09
10:29
03-23-2019
05:09
10:29
Best Answer03-31-2019 11:32
03-31-2019 11:32
Thank you so much for your inquiry. I did get the light on the screen to work. But I have another question...Shouldn't the screen light up when you quickly flip your wrist to display the time ...it does not display unless I press on the side of the device. I can't seem to find the answer online for this.
Thank you for your time.
Chris
04-01-2019
04:20
10:28
04-01-2019
04:20
10:28
Thanks for the update @Lilamom94.
It's great to hear that your display is now working. Now about your inquiry, if you have the screen wake option on you should be able to see your tracker illuminating when you raise your hand. To turn on this feature, do the following:
Let me know how it goes. ![]()
05-01-2019 02:31
05-01-2019 02:31
Hello,
my fitbit charge 3 is only 5 months old (not even) and the top part of the display is faulty, not sure if that can be called fading as it seems more like some of the pixels are not working anymore making black lines over the step counter... how could I get this fixed or replaced?
thanks
05-01-2019 02:47
05-01-2019 02:47
My Charge 3 screen has been dim for most of the time I’ve had it 6 months now. Tried resetting it several times and changing clock faces, nothing makes it brighter . Thinking of returning and asking for a replacement .
08-04-2019 07:14
08-04-2019 07:14
I have tried a restart multiple times. No change in the issue with my Charge 3. Attached is a photo of the display, iDisplay Issue on Charge 3.f this might help to resolve. KM
08-04-2019 08:16
08-04-2019 08:16
Mine started like this then eventually died... I’m waiting for my 3rd replacement now... (1 screen died, 1 didn’t charge and the last one loses battery very quickly and the button is faulty). I’m hoping the 4th one will work..
Best Answer08-04-2019 08:17
08-04-2019 08:17
Best Answer08-04-2019 08:18
08-04-2019 08:18
Mine was still under warranty
if yours is contact the help support they are very helpful and fast to sort issues
07:09
10:28
08-05-2019
07:09
10:28
A warm welcome to the Community @KerMiTT and @Oulema13 thanks for the input.
I appreciate all the efforts in trying to fix this display issue. Since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. ![]()
Best Answer09-02-2019 09:35
09-02-2019 09:35
My screen is fading too. Pls help
09-04-2019 23:43
09-04-2019 23:43
09-05-2019 00:25
09-05-2019 00:25
09-05-2019 00:41
09-05-2019 00:41
Grt. What else could one do?
Best Answer09-05-2019 00:42
09-05-2019 00:42
I have tried everything from restart to change the clock face, nothing is helping. No screen display, no vibrations the tracker is dead.
11-10-2019 08:27
11-10-2019 08:27
This also happened to me just suddenly this morning. And I’m concerned about it getting worse and it dying. My charge three is not very old. Already tried all of the restarting things suggested. Really like Fitbit and prefer not to have to change to Apple Watch or something similar but if it dies again that may be the only option.
06:07
10:28
11-11-2019
06:07
10:28
Best Answer12-01-2019 21:32
12-01-2019 21:32
I am having this same issue. Did you get a replacement?
Best Answer12-01-2019 22:59
12-01-2019 22:59
