01-13-2019
08:52
13:05
01-13-2019
08:52
13:05
I have just charged my Charge 3 and the screen has gone from black to grey with vertical stripes .I have tried rebooting and plugging the charger in again but the screen is still the same.TIA for any help
03-11-2020 12:19
03-11-2020 12:19
03-11-2020 12:33
03-11-2020 12:33
03-11-2020 12:59
03-11-2020 12:59
Best Answer03-11-2020 17:10
03-11-2020 17:10
I think the most irritating thing is that I called them a few months ago and was told an update was coming to fix the issue. So my original call was just about the time my warranty expired and when I call again when nothing changed they wouldn't budge on the issue. I really think I was lied to do it would but then more time to say it was clearly out of warranty and they don't have to cover it. I think it's time to start flooding google reviews and Facebook to let people know not to buy there products.
03-11-2020 18:31 - last edited on 06-05-2020 13:11 by LiliyaFitbit
Good luck in your quest.
Retired Surfer
Sent via my iPad Pro 12.9
03-11-2020 20:07
03-11-2020 20:07
Same situation
Best Answer03-13-2020 09:38
03-13-2020 09:38
Likewise. Just finished with support - mine is just passed 12 months old and they are sticking to it. My charge 2 failed at 19 months. Same story. I'm done with fitbits.
03-13-2020 10:02
03-13-2020 10:02
Best Answer03-13-2020 14:40
03-13-2020 14:40
No, i do not swim. Its been like this for weeks and i have contacted them. No remedy with the restart.
Best Answer03-13-2020 16:00
03-13-2020 16:00
Best Answer04-02-2020 01:57
04-02-2020 01:57
Hi the same problem has happened to my FitBit, have tried restarting but hasn’t fixed the problem
04-02-2020 03:36
04-02-2020 03:36
It is not fixable. You need to get in touch with customer services and if you are in warrenty they will send you a new one. It happened to me twice with the original and replacement so it's obviously a fault with some of the trackers
04-02-2020 03:48 - last edited on 06-05-2020 13:12 by LiliyaFitbit
Call customer service and speak to a real person. You should get a new one
Retired Surfer
04-02-2020 03:53
04-02-2020 03:53
Hi thanks for your reply. They did replace it but now the new one they sent me will not work when you press the button and wont sync. Obviously another fault but I cant find the link to customer services chat. I think they may have removed it at the moment due to Covid. Keep safe and thank you.
Best Answer04-02-2020 03:56
04-02-2020 03:56
You're welcome.. Hope you can sort it soon. Same to you
Best Answer04-02-2020 04:33
04-02-2020 04:33
04-15-2020 17:13 - edited 05-06-2020 18:53
Mine just did the exact same thing , it was functioning fine before I charged it .,update: I contacted Fitbit , reset and reboot did not work , so because I was still under warranty they have sent me a replacement .
Best Answer04-15-2020 18:18
04-15-2020 18:18
Best Answer04-15-2020 19:31
04-15-2020 19:31
04-15-2020 19:34
04-15-2020 19:34
