02-03-2019
15:30
06:31
WilsonFitbit
02-03-2019
15:30
06:31
WilsonFitbit
On my wrist band the Fitbit charge 3 it says not tracking sleep. Why is this?
Moderator Edit: Clarified Subject/format
02-10-2019 16:21
02-10-2019 16:21
02-03-2019 19:47
02-03-2019 19:47
I got that also , but I couldn't get any info for the device
Best Answer02-03-2019 19:48
02-03-2019 19:48
I don't know how they can charge so much for these when they don't work
02-03-2019 20:08
02-03-2019 20:08
Best Answer02-03-2019 21:01
02-03-2019 21:01
Make sure when you go into the app on your phone you click on the sleep icon, then the gear/setting button, then have 'Receive Sleep Insights' turned on. Otherwise double check you have bluetooth enabled
Best Answer02-04-2019 01:25
02-04-2019 01:25
Best Answer02-04-2019 02:50
02-04-2019 02:50
Also take note ; automatic sleep tracking on the charge 3 only starts after you've been lying still for an hour. I found that the best way to get somewhat accurate reading on my sleep patron was to start and end my sleep manually in the app and then the next morning, through trial and error, set the correct begin- and end-tie for my sleep period to see the different stages of sleep.
02-04-2019 05:47
02-04-2019 05:47
I slept all night and it didn't do anything. I will never buy another one of these and I will tell everyone I know not to buy them to until it tracks my sleep like the charge HR did.
02-04-2019 06:37
02-04-2019 06:37
My Fitbit 3 says sleep not tracked?How do I fix this
02-04-2019 09:50
02-04-2019 09:50
My charge 3 doesn't seem to start my sleep cycle until 3 - 5 hours after I think I fall asleep. Can you elaborate a little more about setting sleep manually? I have read the manual but it's not clicking in my mind.
02-04-2019 11:14
02-04-2019 11:14
Hello @Gerlof101, @Lonewolf269, @Krabr, @caitlindurbin, @sehertz and @idowu12, have a warm welcome to the Fitbit Community. It's nice to see you too @CHRISARL, I hope you're doing well. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. Tell me, have you tried to restart your Charge 3 lately? Please note that as mentioned by @Gerlof101, your Fitbit device starts recording your sleep after it hasn't detected movement for 1 hour. Additionally to restart your device, please try to use it on your other wrist and make sure you're getting a constant heart rate reading before going to bed.
I hope this can be helpful, give it a try and let us know the outcome.
Best Answer02-04-2019 12:16
02-04-2019 12:16
I have tried all the suggestions and it still reads " sleep not tracked" There must be a repair or fix. When your earlier versions were able to manage sleep patterns and did them so well. By the number of frustrated consumers,, it does not look good for your company.![]()
02-04-2019 13:22 - edited 02-04-2019 13:23
Tell me about it, they should be able to fix this with an update we shouldn't have to spend half our life trying to restart the stupid thing. If the old charge HR could track your sleep wonderfully why can't this one, and do it better. What is wrong with this company.
02-04-2019 13:28
02-04-2019 13:28
I had the issue once.
I plugged it to the chargedand restarted the fitbit.
It works perfect since that.
Best Answer02-04-2019 14:08
02-04-2019 14:08
Thanks,, now on my wristband it says it's tracking sleep and shows the sleep I had last night we'll see if it changes tomorrow morning
Best Answer02-05-2019 09:56
02-05-2019 09:56
Well this morning, it track my sleep, it took a while for it to show that on the app. Then 2 hours later I went to sync my device again and the app could not find my device was paired in Bluetooth. So now I don't know what to do because the app can't find my device. This thing is a pain in the butt
02-05-2019 10:48
02-05-2019 10:48
Best Answer02-05-2019 10:52
02-05-2019 10:52
I did that, I also clear the cache from the app and Bluetooth. Still didn't work. I had to totally restart my wristband delete it from the app and go for the whole setup system again to get it to work. This is too much work for something that's supposed to be better than the HR. And I can't go back to my HR because it's screwed up now. I will never buy another one of these.
02-05-2019 12:56
02-05-2019 12:56
Best Answer02-09-2019 14:16
02-09-2019 14:16
Thank you for your comments @lostintech, @Lonewolf269, @gquintas and @CHRISARL.
Welcome to the Fitbit Community @lostintech, and thank you for confirming that you already tried all the basic troubleshooting steps. I've sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
I'm sorry to see that you've trouble to get the sleep information as well @Lonewolf269, @gquintas, @CHRISARL, but it's good to know that you were able to get it to work again and your sleep information is being displayed.
Keep us posted.
