11-03-2020
15:12
13:01
11-03-2020
15:12
13:01
Screen slowly started fading and then seemed fine. Went to sleep and when I woke up the screen was blank and would not turn on as I've seen many others have the same issue. I've tried all the fixes on previous threads and nothing seems to help. Any help would be appreciated.
11-03-2020
15:37
04:40
DavideFitbit
11-03-2020
15:37
04:40
DavideFitbit
Mine as well, though I can see it in the dark, dimly. Also, the haptic feedback isn’t working on starting the exercise.
*Found out the device was put into the sleep option, if you plug it in, hold the button ..in a dark room..and the sleep option should be visible, touch that. Worked for me. You and I aren’t the only ones..
11-05-2020 04:38
11-05-2020 04:38
Hello @Neal1, and welcome to the Fitbit Community forums @DebbieRi, I'll be glad to help you with this.
Thank you for sharing that you've been having trouble with the display of the Charge 3 that is too dim or dark and that you've tried the recommended troubleshooting steps found in the forums.
@DebbieRi, in addition to the steps you mentioned, could you please confirm if you have tried to disable the Sleep Mode and Do not disturb features on the device, as @Neal1 mentioned earlier?
Let me know if you're also referring to the troubleshooting steps mentioned in this other thread of the Community, or which are the steps that you already tried.
Please keep me posted.
Best Answer11-05-2020 05:23 - edited 11-06-2020 06:53
Hi David, we have the answer.
Edit: nope, not at this time :), still need one.
Best Answer11-05-2020 11:08
11-05-2020 11:08
Hi @DavideFitbit and @Neal1 thank you for your help.
I have tried the disable the sleep mode in a dark room but don't get anything on the screen it is completely blank.
I have also tried the clock face change and the full reset as shown in the thread, I have the vibrations from the Fitbit but can't see anything on the screen.
Best Answer11-05-2020 11:47
11-05-2020 11:47
Ouch! I thought it was answered.
Best Answer11-05-2020 12:52
11-05-2020 12:52
Nope, it connects to the app and still works fine and vibrates, just have a black screen and can't see anything on there, not good as I keep checking it.
It is doing my head in now, didn't realise how much I relied on it till you can't see anything...
11-06-2020 02:01
11-06-2020 02:01
@Neal1and @DavideFitbit how do I get the answered removed from the top as it hasn't been answered and still need this sorting??
11-06-2020 06:47
11-06-2020 06:47
Got me on the removal, but there sure are a bunch of posts about blank screens, you can still follow those answers.
Bummer you can’t navigate to the settings. What would be helpful is if users could reach ALL settings available on the tracker only, on the dashboard as well. I just checked my dashboard and pretty much none of the actions in “settings” on the tracker are in “settings” on the dashboard.
11-06-2020 08:34
11-06-2020 08:34
Hi, thank you for sharing this update confirming that you already tried all the suggested steps @DebbieRi.
I've gone ahead and sent your information to the Customer Support team for further assistance with this, so you should be getting a reply soon.
Let me know if you have further questions.
Best Answer11-06-2020 09:38
11-06-2020 09:38
@DavideFitbit thank you for referring me to customer support, I will await a response from them.
Best Answer11-06-2020 09:42
11-06-2020 09:42
@Neal1 I know I was thinking the same would make more sense to be able to do these things on the dashboard as well.
I have been referred to customer support, so let's hope they can sort this for me.
Thank you for your help, much appreciated.
11-07-2020 15:44
