01-22-2019
18:35
13:05
01-22-2019
18:35
13:05
I was having an issue where my Charge 3 wouldn’t sync to my Galaxy S8 anymore and then suddenly today the screen froze. It is stuck on the number of floors. Plugging into charger and holding in button won’t restart it. Don’t know what happened or how to fix.
06-06-2019 10:43 - edited 07-05-2025 08:02
Welcome on board @Loveparis! Thanks for already restarting your Charge 3 in order to solve the issue with the screen.
Since the restart hasn't worked for you, I suggest to restart Charge 3 using the 15-second method:
If the long restart does not work either, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome. I'll be here and glad to further assist you. ![]()
01-23-2019
09:16
08:01
01-23-2019
09:16
08:01
Welcome to the Community @Kmanfred.
Thanks for troubleshooting this display issue by yourself. Please make sure to do the following in order to restart your tracker:
Let me know the outcome. ![]()
01-23-2019 14:08
01-23-2019 14:08
Best Answer06-06-2019 07:05
06-06-2019 07:05
Thanks, I just used this fix aand it works prefectly! ![]()
Best Answer06-06-2019 08:42 - edited 07-05-2025 08:01
Welcome on board @jog916! We're glad to hear that the steps provided above fixed the issue with your Charge 3.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted.
I hope you have a great day! ![]()
06-06-2019 09:19
06-06-2019 09:19
I did this and it worked to unfreeze but lost all the info for the day prior to that.
Best Answer06-06-2019 09:54 - edited 07-05-2025 08:01
Welcome on board @Dierickson! What happened to you is an expected behavior. You should have logged in to sync the tracker before doing this procedure. Even when the tracker's display was frozen it might have been able to sync.
If you remember the exact amount of steps or the name of the activity you performed, you can try manually logging the activity. To get more information about this, check the article: How do I manually log an activity or exercise?
Additionally, it'd be great to take a look at: How do Fitbit devices sync their data? to get more information about how your Charge 3 syncs.
Hope this clarifies what happened. Let me know if you need further assistance.
06-06-2019 10:30
06-06-2019 10:30
My fitbit had frozen. The only thing that moves is the time. It won't let me swipe to check my steps or anything. I am updating it right now. Please help if the updating doesn't work. I also tried plugging it in and holding it for 8 seconds , but it doesn't work at all.
Best Answer06-06-2019 10:43 - edited 07-05-2025 08:02
06-06-2019 12:04
06-06-2019 12:04
Best Answer06-06-2019 12:12 - edited 07-05-2025 08:02
Awesome @Dierickson! I'm very glad to hear that you're back on track. Thanks for letting us know what has worked for you. ![]()
Please don't hesitate to let us know if there's anything else I may do to assist you with.
06-06-2019 22:21
06-06-2019 22:21
Best Answer06-06-2019 22:22
06-06-2019 22:22
Best Answer08-13-2019 11:12
08-13-2019 11:12
Thank you so much!
I was in school and didn't have my charging cable to reset the watch.
So I changed the clock face and then changed it back and it fixed it!
Thanks!
08-15-2019 08:55 - edited 07-05-2025 08:02
Welcome to the Community Forums @slavkoles! I'm glad to hear that changing the clock face has worked for you.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! ![]()
08-23-2019 22:56
08-23-2019 22:56
Reset and reset and reset many times each day. Changing the clock face only works temporarily. Mine gets stuck anytime I swipe left. This is a joke !!!
08-24-2019 08:05 - edited 07-05-2025 08:02
@nanachris52 Welcome on board. I totally understand how you feel. Thanks for following the tips and recommendations provided here.
Since none of the steps you tried have worked, I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if you have any questions present.
11-18-2019 09:42
11-18-2019 09:42
Thanks you - Thank you - Thank you
This worked perfectly for me.
11-18-2019 10:52 - edited 07-05-2025 08:02
Hi there @SheKai, thanks for stopping by and letting us know that the steps recommended here worked for you.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted! 😉
Best Answer11-18-2019 18:10
11-18-2019 18:10
