02-27-2021
21:05
03:01
WilsonFitbit
02-27-2021
21:05
03:01
WilsonFitbit
My Charge 3 screen is fading. I've seen a couple other similar posts in the community and the advice given is to reset the fitbit while on the charger. I have done that and it did not solve the issue.
02-28-2021 00:45
02-28-2021 00:45
Fitbit's advice for those having this problem is at Check here for help with Charge 3 screen issues - Fitbit Community
As you've already tried the restart, the next step would be to contact customer support. They can check your warranty status and advise on your replacement options.
