Charge 3 screen went blank
ANSWERED
I've had my Charge 3 a little over a month. Last night my screen went blank. It was at 100% battery. It is still syncing with the app so I can see that it is still tracking my steps and sleep, etc. When I tried to restart it by placing it on the charger and holding down the side button for 8 secs. When I hold the button down it does a very quick pulse vibe about 4 times and then nothing. I've tried holding it longer than 8 secs also and still nothing. Very frustrated to be having this issue with a brand new product. Contemplating returning the one I bought my husband for Christmas and returning mine as well if not resolved immediately.
620 REPLIES 620
Mine too. I’m lost with this now!!
Sent from my iPhone
I put my fitbit in the charger overnight and tried again. Same result.
Smiley face, screen comes on then disappears. 😞
Don’t know, if you are doing what I said I have no more to suggest
Sent from my iPhone
I worked with the Fitbit customer service person on a very long chat today
and after trying all the suggestions they are sending a replacement unit as
mine has now been declared deceased.
Result for you - I only got mine for Christmas and set it up 3 Jan. It vibrates but screen remains black. ☹️☹️
Sent from my iPhone
Got time over the weekend to keep trying all the suggestions. It vibrates but nil appears on the screen. Maddening.
Sent from my iPhone
If you go on the chat in the help section of the web site they will walk
you through how to fix it. If not fixable they will replace it.
Mine just went blank. I’ve tried this reset that they told us. It is not working.
I have used Fitbit for over 5+ years. This is the first time I’ve had the screen issue. And my charge three is not that old. There’s definitely got to be a glitch in the system. Especially since it’s happening to so many people. Hopefully they find the bug somewhere.
this fix worked for me after the 2nd try. so I am happy about that but wonder why the screen is going black in the first place? It is only a month old!
Don’t know the answer but mine is 2 yrs old
Sent from my iPhone
@AlexandraFitbit Mine has done it 3 times and was able to get it back running. However, now it is blank and will stay black screen. The most I have been able to do is get a white line to apppear on screen when it is on charger. It will not track steps or sync now either. I’ve done the reset sequence at least 6 times each 3 days in a row
Mine starting having problems last week with step counting being way off. I did a reset and that "cured" the problem. Last night, it happened again and this morning I awakened to a blank screen. I did all the reset suggestions with no result. I have a heart issue in which I have to track heart rate so it is important to me that I can quickly look to see current rate. I also am now getting back into exercising after a hospitalization, so that info is important also. The tracker transmits the info to the app but I just can't see the info on the tracker screen.
I contacted via Chat customer service  a few minutes ago and within 5 minutes of chatting my tracker is being replaced by Fitbit. I could have chosen the option to upgrade at half price but right now, the Charge 3 works for me....when it works. I don't need a smart watch with Alexa.
Apparently this issue is affecting a large number of Fitbit users. I believe Fitbit should issue a detailed solution or provide a replacement even for those our of warranty.
I called and after repeating the steps that I've tried numerous times they
are sending me a new one for free
Regards,
Is it still under warranty?
thankfully yes they are replacing it for free.
they are replacing mine too.
Even if you think it's out of warranty it's worth contacting them - I thought mine was out of warranty but they sent me a new one
I think they are good and flexible when it comes to the warranty. When did
you purchase yours ?
