03-11-2019
10:15
11:22
03-11-2019
10:15
11:22
My strap has broken on my Charge 3, it is only 5 months old. Is it possible to get sent a replacement please? The buckle has come off because the little loops have snapped.
Thanks.
03-12-2019 01:30
03-12-2019 01:30
Hi @Irene87
In order to make a warranty claim you need to contact customer support via contact.fitbit.com
03-12-2019 01:30
03-12-2019 01:30
Hi @Irene87
03-13-2019 10:15
03-13-2019 10:15
It's great to see you here @Irene87 and @SteveH thanks for the input.
I was able to see here that our friend @SteveH answered your question about your Charge 3 wristband warranty.
If this answer was the one you were looking for, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
05-12-2019 04:02
05-12-2019 04:02
Same happened to mine and I had mine < 5 months! 😭
06-20-2019 10:43
06-20-2019 10:43
I have the same problem, in 6 months the strap is broken. https://photos.app.goo.gl/PcQfqXobeVPRYh6R7
08-01-2019 12:57
08-01-2019 12:57
Same here, it just fell off from my wrist last night while sleeping
08-07-2019 01:44
08-07-2019 01:44
08-23-2019 10:00
08-23-2019 10:00
same with mine after 10 months... just had a chat session w agent who confirmed my warranty and is sending a replacement. I'm hoping it is an updated version of the band, but guessing it is the same which will most likely break again in less than a year. disappointed in the quality for sure.
08-23-2019 14:35
08-23-2019 14:35
I also got a replacement from support, hope its an updated version.
I wish I could pay $5 more to get a different one...
09-02-2019 10:59
09-02-2019 10:59
mine will be replaced at almost 11 months.
09-03-2019 21:46
09-03-2019 21:46
Same here. My Fitbit isn’t even a full 9 months old, and already the band broke. Last month, the Fitbit tracker itself had an issue after the newest update and was sent a replacement. Maybe there is a faulty issue in the band as well?
09-12-2019 02:05
09-12-2019 02:05
Hi there, did the replace the straps or the whole tracker? I have the same issue and I am waiting for feedback from Fitbit
09-12-2019 02:08
09-12-2019 02:08
09-12-2019 02:12
09-12-2019 02:12
09-12-2019 09:33
09-12-2019 09:33
They replaced your strap?
You’ll know if your Fitbit has issues from the update. It will be VERY obvious. But they replaced the tracker only. (Plus my tracker was under warranty. I’m not sure if the warranty covers the band too)
09-12-2019 16:23 - edited 09-12-2019 16:24
Yes I have gotten the strap replaced. It's under the warranty. My tracker looks ok for now.
09-25-2019 12:51
09-25-2019 12:51
can you share that image with me? I'm trying to get a warranty replacement for my Charge 3 strap, but I already threw my broken strap away! I tried to see the image you attached but it says the album is empty. Thanks!
11-19-2019 20:30
11-19-2019 20:30
Same thing happened to mine. 6 months.....
01-17-2020 08:13
01-17-2020 08:13
My strap on my charge 3 broke after only being a little over one year old. Contacted Fitbit & they will not replace the band for free. Very Disappointed
01-18-2020 09:32
01-18-2020 09:32
