11-26-2018
22:15
14:34
11-26-2018
22:15
14:34
hi, i just bought charge 3, and it can't be turn on. when i plug to the charger, it's only vibrate, i try to restart it, i pressed for 8 seconds then the smiling face comes up but then it shut down again.
10-08-2021 12:21
10-08-2021 12:21
Welcome to the Fitbit Community, @JanCP.
Thank you for joining the thread and sharing the details of the issue with your device. I appreciate your troubleshooting efforts and would like to confirm if you've tried the following:
Hope this helps.
11-27-2018 02:19
11-27-2018 02:19
I think you will need to return it to the store you bought it or contact Support (link in my signature)
Helen | Western Australia
11-27-2018 06:19 - edited 11-27-2018 06:23
Welcome to the Fitbit Community @Hastech, hope you're doing great! Thanks for taking the time to troubleshooting this inconvenience, nice way to go! To test the screen:
Thanks for you help @NellyG!
If there's any questions, let me know!
06-01-2019 07:36
06-01-2019 07:36
Hi, I've tried all of these suggestions and my screen is still black. Are there any other options?
06-10-2019 10:07
06-10-2019 10:07
Mine is doing the very same thing. I have done a soft and hard reset but the fitbit will only come on in the charger. When I take it out the face is blank and will not come on. 😩😩😩
06-10-2019 10:44
06-10-2019 10:44
I have changed the clock face, done the restarts, left the device on the charger over night to make sure it charges. I am not sure what else to do.
07-23-2019 11:58
07-26-2019 05:16
07-26-2019 05:16
I've tried several time to do long restart and wont turn on. I even tired changing the clock face with the long restart and still won't turn on
07-26-2019 07:23
07-26-2019 07:23
07-26-2019 11:49
07-26-2019 11:49
Call them directly. Their service was awesome. Ended up needing a replacement pebble. Keep your wrist bands and charging cable. Give them a call.
07-26-2019 13:36
07-26-2019 13:36
Hi I have done the hold button for 15 seconds.took of charger then put back on charger.Nothing happens and I dont get a smiley face
07-26-2019 13:43
07-26-2019 13:43
I ended up calling customer service and they are sending me a new one after I ship it back to them. It was still under warranty so give them a call
07-26-2019 15:10
07-26-2019 15:10
Whi did you contact to get replacement?
07-26-2019 15:24
07-26-2019 15:24
I contacted because I tried all the ways to reset and nothing worked
07-26-2019 23:16
07-26-2019 23:16
Are you in the uk ? I cant find there number anywhere
07-27-2019 11:43
07-27-2019 11:43
Very bottom of this page should have an "about us" tab which takes you to another page, click on "contact us" you should find customer service numbers there. They will assist you for sure. They are wonderful!!
07-31-2019 19:54
07-31-2019 19:54
I have tried the hard reset and I still do not get any results. My fitbit is less than 2 years old. I do not get it wet, it is cleaned, and always charged. It vibrates when plugging in and holding down the button but nothing comes on the screen
07-31-2019 21:26
07-31-2019 21:26
08-01-2019 02:28
08-01-2019 02:28
09-01-2019 14:04
09-01-2019 14:04
I am having issues with a charge 3 which is less than 3 months old. The watch was working fine until about4 Or 5 days ago when the battery ran down quickly. It now lasts 4 or 5 hours off a full charge. I have used multipmedifferent usb plugs as well as a usb connection to my laptop. It charges to 100%but runs down quickly. I have done multiple 8 sec restarts as well as multiple 15 sec restarts. Not sure is the battery just faulty
