03-21-2016
18:01
20:15
03-21-2016
18:01
20:15
Hi There. My fitbit charge HR is onle 7 months old and it (for some reason) has stopped working.
I charged it last night, put it on this morning fully charged, checked the time at 830 ish and the time was off by about 25 mins. I synced to my android phone app and the time corrected itself on the fitbit. Not even a half hour later i tried again to check the time - it only had the fitbit logo and the version number (122) then went blank again. As of noon or so today I can even get the fitbit to turn on or show anything on the screen. The heartbeat monitor light isnt even on and now I cant connect to it via bluetooth or via the cord.
Please advise how to correct this asap
03-26-2016
12:34
04:51
03-26-2016
12:34
04:51
Hey hey hey @AmandaR1987 welcome to the Forums! This sounds a little weird. But don't worry, I believe that this could be fixed by restarting your tracker, so please just follow the instructions on this post. If after that the display is working, leave your Fitbit charging for around 2 hours until is fully charged.
Let me know the outcome. I'll be around.
06-13-2016 07:19
06-13-2016 07:19
I'm having similar issues with my Charge HR. It just stopped working this Saturday and I have gone through the reset procedure mutliple times to no avail. I'm not sure what else to do. I put it on the charger over night in hopes that that would help but it doesn't seem to be doing anything. Seems like people are getting really lucky with getting theirs to work after this happens.
I purchased my fitbit from my T-Mobile store. If nothing is working for me would I just take it back there?
03-26-2016
12:34
04:51
03-26-2016
12:34
04:51
03-26-2016 18:37
03-26-2016 18:37
This totally helped. I had given up...packed it up and was ready to start a warrenty claim. But this post did the trick...Thank you!!
06:22
04:51
03-29-2016
06:22
04:51
Thanks for getting back to me @Grimus24! it's pretty cool to hear that the previous post helped you out with this issue and I appreciate you are letting me know about it so other users can use the same instructions if they are experiencing the same problem.
I'll be around if you need more assistance.
04-05-2016 07:26
04-05-2016 07:26
I'm having a similar problem as above. (Which is the same/simlar problem I had when I first received my HR for my birthday in March. My HR simply quits working in the middle of the day. Last night it stopped in the middle of the night; recording only 4+ hours of sleep. I rebooted it when I first got up this morning...and now it has stopped working AGAIN, about a 1/2 hour ago. Very, VERY FRUSTRATING! So what needs to happen to keep it going? ...And do I always have to keep my charge cord with me? (THAT would be a drag.) I want this product to be a little more dependable than it's showing itself to be.
07:50
04:51
04-06-2016
07:50
04:51
Hi @rich99 welcome to the Community!
Sounds too bad that your Charge HR is giving you these issues. Let me suggest you to get in touch with Fitbit Support, our team will take a look of your account and give you the best solution to get you back on track!
Let me know how it goes!
04-07-2016 19:39
04-07-2016 19:39
My Charge HR suddenly has stopped registering anything but the time. Several times I tried the reboot (holding the button until the version displayed and it took longer than the advertised time) after a complete charge.
I'm really frustrated. Having paid a not insignificant amount for this product, I expect it to function reliably. I've had this for less than two months...
06:55
04:51
04-08-2016
06:55
04:51
Hi there @wantsreliable let me give you a warm welcome to the Community! This sounds too bad. And I appreciate you have taken the time to try to resolve this by restarting your Charge HR. So now, the best option is contact Fitbit Support directly, they will take a look into your account and pick up the best option for you. ![]()
I'll be around if you have more questions!
05-12-2016 06:16
05-12-2016 06:16
I have had my Charge HR for less than 24 hours and I cant set it up or anything.I charged it right away and then tried setting it up and the only thing I can see is the logo and the version 122. Really disappointed right now. I ordered it off Amazon for myself for my birthday.
06:57
04:50
05-14-2016
06:57
04:50
Hi @Baylee13 welcome to the Community!
The 122 that you are looking on the display is the firmware version of the tracker, however it seems pretty weird that it is the only thing you can see, so let me suggest you something, please try to restart your Charge HR by following the instructions on this post and then try to set up your tracker again.
Let me know if that works!
05-31-2016 07:50
05-31-2016 07:50
My Fitbit Charge HR stopped working. I let it charge overnight. Now it doesn't read anything; steps, heart rate... nothing! I called Customer Service only to be told since it is 15 months old, it's out of warranty (I've had problems for the past 6 months) and there's nothing they can do about it, but give me a 25% discount on a new one. I will never own another Fitbit.
Very sad. I really wanted it to work. Will be sharing this with my trainer and everyone I talk with.
06-02-2016 22:20
06-02-2016 22:20
FITBIT HR just stopped working a couple of days ago. Charged overnight, no display. My unit is only about 10 months old. Well taken care of, not abused. Have contacted support. Hopefully they will be able to offer some options.
I see this is not an uncommon trait for other FITBIT HR users.
06-03-2016
07:13
04:50
06-03-2016
07:13
04:50
Hey, @pammis, @kein!! Welcome to the Forums! @pammis, I'm sorry to hear about your situation.You should not charge your tracker for more than 2 hours since that is all it needs to get a full charge. This can cause the battery to overheat and get damaged. You can read all about our warranty policies, here.
Hey, @kein! Just a question. Have you tried to restart it to get the display fixed? What did Support say?
Keep me posted!![]()
06-03-2016 08:32
06-03-2016 08:32
Thank you for your response!
I'm glad I didn't read this last night, because I left my Charge HR plugged in all night, got up this morning and tapped on the display and it sprung to life. Go figure. Nothing else worked.
Electronics are supposed to have a designed method of responding, not by chance. This leads me to believe there are many things about the Charge HR (based on what others have shared) that aren't understood and perhaps are not well designed.
In any case, I'm glad it's working and I hope it isn't just a short spurt before it dies again.
Best Answer06-03-2016 09:35
06-03-2016 09:35
06-04-2016
06:11
04:50
06-04-2016
06:11
04:50
Best Answer06-13-2016 07:19
06-13-2016 07:19
06-13-2016
10:26
04:18
JuanJoFitbit
06-13-2016
10:26
04:18
JuanJoFitbit
I'm having a similar problem. I've had my Fitbit charge HR for about six months. It was work thing great last night. When I woke up this morning, it just stopped working. And I know the battery was charged at least half. I've tried following the instructions to reset my Fitbit numerous times, but nothing happens except the light from the sensor will blink pence then it's back to nothing. Help please!
Scratch that, now nothing's happening, not even the green light.
Moderator edit: merged reply
Best Answer06-13-2016 11:27
06-13-2016 11:27
Folks...I was in touch with the FitBit folks & they sent me a new device. (I had only had mine about a month.) Once I figured out how to "disconnect" my old one & "connect" my new device, I've not had a single problem with my FitBit Charge HR. (I DO wish they'd include some sort of instructions. THAT was rather frustrating!) ...But, all is well now.
Best Answer06-13-2016 15:01
06-13-2016 15:01
