The message you are trying to access is permanently deleted.
06-21-2016
20:18
17:01
06-21-2016
20:18
17:01
06-22-2016 05:03
06-22-2016 05:03
Welcome to the Community @lovebursts! I must say that this really odd. Since you have already done the suggested troubleshoot to fix this issue, I recommend manually logging an activity by following @GisselleM's instructions in this post. Enter something like "Walk" and in the zone highlighted below instead of distance enter steps and choose the amount of steps you need.
I hope this helps. Let me know how it goes.
Best Answer06-22-2016 05:03
06-22-2016 05:03
Best Answer06-29-2016 15:29
06-29-2016 15:29
06-30-2016 05:55 - edited 06-30-2016 05:56
@Bekett Welcome to our Community! Have you logged any activity recently on your account? This may decrease your step count. Also do you sync your tracker daily? If you don't then your track will lose the correct time and could assign your steps on a different day once you sync. You can also log a walking activity to have a record on your account like @SunsetRunner suggested in his post.
Let me know how it goes!
06-30-2016 06:19
06-30-2016 06:19
Hi AlvaroFitbit;
Yes, I log activity every day. (I eat based on my step count!) Yes, I sync my tracker at a minimum 3 times a day. (This is a frustrating experience as at least once daily it says it can't either find my tracker or fitbit.com.) I added what I guessed the step count to be, but I like to be as accurate as possible as like I said, I eat based on my calories available. (I've lost 32 pounds since 9/29/15 doing this and I don't want to ruin everything with bad calorie counts!)
Thanks for your input.
06-30-2016 17:10
06-30-2016 17:10
07-03-2016 04:47
07-03-2016 04:47
@Bekett So you have a Charge HR and a Zip tracker paired to the same account. I would suggest you actually remove the Zip from your account and wear your Charge HR for the next couple of days. Let me know if the steps are removed from these days once you only have one tracker on your account. Also when removing the Zip please do so early in the morning so both trackers don't have many steps recorded at that time.
I look forward to your reply.
07-04-2016 07:51
07-04-2016 07:51
07-05-2016 05:31
07-05-2016 05:31
AlvaroFitbit - thanks for your help - I called Customer Support on Saturday and they took me through the same steps I had done on Thursday/Friday to try to correct the issue and it still didn't work. They are sending me a new HR. Great experience with CS!
07-05-2016 05:33 - edited 07-05-2016 05:33
@Sheda610 - I finally called customer support - great experience and my new HR is on the way! Can't hurt to call them. On the app - go to devices - then Help - then contact customer support and you can call right there.
07-20-2016 07:10
07-20-2016 07:10
@Sheda610 Welcome to our Community! @Bekett is right. The Support Team is able to see your tracker in greater detail so they can determine if it defective. You might want to contact them to see what they can do for you. You can also find additional contact channels here.
@Bekett Happy to hear that you got a replacement tracker from them!
Best Answer11-07-2016 12:45
11-07-2016 12:45
This is very dissapointing.
My tracker started deleting steps and burned calories as well. I just had it replaced 6 months or so ago (my first one died after 4 months. It would not charge or turn on). That is pretty expensive device that does not tracks actvity correctly and last 6 months on average. I had my Bodybugg for 9 years before I started having problems.
11-09-2016 06:18
11-09-2016 06:18
@UV Welcome to our Community! How often do you sync your tracker? Are you logging any activity (swimming, bicycling, driving)? You can always try restarting your tracker by doing the following:
1.- Plug your charging cable into the USB port and insert the other end into the port on the back of your Fitbit Charge. Your Charge will begin charging.
2.- Press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number (e.g. "V30").
3.- Let go of the button.
4.- Unplug your tracker from the charging cable.
You could also try removing the tracker (click at the bottom where it says "Remove this Charge from your account) from your account and set it up again.
Best Answer11-09-2016 15:36
11-09-2016 15:36
Best Answer11-11-2016 09:43
11-11-2016 09:43
Nice to see you here @Debk1945! ![]()
Let's try to log activities back to your App. Follow this quick steps to log a walk activity, to have steps back to your Dashboard. If you're going to use an iOS device you can try these steps:
When you choose the option "Walk" enter the duration and day and log the activity. Depending on your profile information a walk activity of 30 mins. will give you around 2700 steps for example.
After doing this, sync your tracker with your App. Confirm that it is connecting properly and let me know how it goes.
I'll be around in case that you need anything else! ![]()
07-13-2019 10:57
07-13-2019 10:57
I am having the same problems.
My sleep monitoring isn’t showing up at all!
Best Answer06-13-2021 21:00
06-13-2021 21:00
This happens to me very often with my Charge 4. Seems like this is a common issue that needs to be addressed. Tired of doing all these work arounds. This is my 3rd Fitbit device. This charge 4 is so glitchy! About half the fancy features don’t work at all. Seems like it could at least count steps properly.
