12-27-2016
12:16
09:31
AndreaFitbit
12-27-2016
12:16
09:31
AndreaFitbit
So I am trying to upgrade the look of a fitbit to blend in with my wardrobe more but the replacement bands have magnets and I am wondering if they will interfere with the fitbit technology?? Has anyone heard of anything or had good/bad experiences with magnets near their fitbit?
I included a link to the fitbit band I'm looking at if that helps! Thanks to anyone who has helpful info!
https://www.amazon.com/gp/product/B01M0599ZS/ref=ox_sc_act_image_1?ie=UTF8&psc=1&smid=A23K4BMC7EI317
Moderator edit: format.
09-04-2019 15:05
09-04-2019 15:05
09-04-2019 15:46
09-04-2019 15:46
Best Answer09-24-2019 23:12
09-24-2019 23:12
I know that it is an old post. But is there conclusion about this topic?
I just bought my inspire HR and replace the band with the magnetic one I bought online. When I wear the magnetic band, the HR reading is not normal, it shows very high HR. I compare the result by wearing 2 fitbit at the same time (one belong to my husband, same type, with rubber band) and the HR reading in my husband's fitbit is normal.
Now i switch back to wear the rubber band and the HR reading is normal.
I want to be able to wear the magnetic bands because it's prettier and doesn't cause rash, but it seems impossible, I'm stuck with the rubber one 😪.
09-25-2019 00:33
09-25-2019 00:33
Best Answer09-25-2019 07:07
09-25-2019 07:07
Best Answer09-25-2019 07:15
09-25-2019 07:15
I've had a Versa for nearly a year with a magnetic band which I like because it can be adjusted precisely unlike the plastic bands. My wrist size changes throughout the day depending on if I'm active and working hard or sleeping. So far the only time my Versa gives me a bogus heart rate is when I lift weights. During all other activities, it is accurate. The mag band also allows sweat to evaporate more easily as well, so I don't get a rash under it.
09-25-2019 08:18
09-25-2019 08:18
This makes no sense since magnets do not affect light in a strong way.
09-25-2019 08:28
09-25-2019 08:28
So, from what i read from the replies, the magnetic band works fine in charge 2 and versa (even though for some people it doesn't)
Logically the magnetic will not interfere because it's location is all the way on the other side of the wrist, but it happens.
Hopefully there will recommendations from fitbit regarding this magnetic strap problem
Best Answer09-25-2019 08:30
09-25-2019 08:30
Best Answer09-25-2019 08:48
09-25-2019 08:48
@Indiet to add to your logic, the Tracker dies not have a compass or any other device that is affected directly by magnetic waves. This would be a problem since the earth is one big magnet.
The sensors in the tracker simply measure changes in speed (acceleration) this would also include changes in direction of movement.
12-27-2019 10:36
12-27-2019 10:36
I know this is an old thread, but again, this is the first thing that came up in the search... just started using a band with magnetic clasp. 1 day later the fitbit display is no longer working. The watch itself seems to be working, based on the information captured in the app. I have a Versa that's about a year old...
Best Answer12-27-2019 11:10
12-27-2019 11:10
10-29-2020 18:37
10-29-2020 18:37
So, this is my experience. I have had to replace 2 FitBit Charge 2s, after the screens got lines on them and became difficult to read, also the first one stopped holding a charge. My 3rd one has worked great for the last year, the other 2 started having problems after 6 months. The only difference is that I haven't worn the mesh bands with the magnetic closure with this one. I love the look of the magnetic bands, but I'm not willing to risk it again.
Best Answer04-09-2021 20:13
04-09-2021 20:13
My experience: magnetic bands absolutely affect the Fitbit, with a caveat. As long as you're wearing it, it's fine. If/when you take it off, I reccommend unclasping it all the way and laying flat; although I can't say definitively it would matter. BUT I did not do this; I just loosened the band, slid it off my wrist, & set it down; to where the magnetic clasp aligns right along the tech bits on the back of the tracker. I went through THREE Charge 3's. The magnet messed up the first one I bought; I was sent a replacement that was already defective, and the magnet messed up the second replacement until it wouldn't even turn on. This was over the last year or so. I gave up on it. I just got a charge 4 today and I will not be getting a magnetic clasp band. I really liked the one I had but it's just not worth the risk. Some people don't have issues at all. Maybe they were more careful with theirs than I was with mine. But there's no disclosure saying keep the magnet from direct contact with the tracker. Hope this helps.
Best Answer04-09-2021 20:25
04-09-2021 20:25
Your tracker doesn't have any sensors to detect magnetic waves.
Best Answer04-10-2021 06:22
04-10-2021 06:22
Best Answer04-08-2022 05:36
04-08-2022 05:36
I noticed my resting heart rate registers 10 points higher and the increase corresponds with when I got a metal band to replace the original.
Best Answer09-10-2022 02:51
09-10-2022 02:51
Just chipping in to say this is exactly my experience. Had a Charge 3 that held on for several years perfectly fine. Gone through a few rubber straps so figured I'd try a metal-magnetic strap for a change. Lasts barely a few weeks before I start seeing lines striking through the screen, making it difficult to read and causing the device to fail to recognise inputs and buzzes by itself. The next day there were even more lines making the screen barely readable, and by the end of the day the screen was completely dead.
tldr; Do not buy magnetic straps for your Fitbit as they will destroy your device.
I've now moved onto a Charge 5 and while I'm still not fond of the rubber straps, I will try a leather one instead. Never using a magnetic/metal one again.
09-10-2022 13:04
09-10-2022 13:04
I've had bands with magnetic claspsgon most of my fitbits. Charge 2,, 3, 4, Versa 1, 3, Sense, Inspire, maybe more, and never had any issue.
With the wrist in-between I would not expect interference.
Best Answer09-10-2022 21:53
09-10-2022 21:53
Perhaps whatever brand of straps you use is more reputable - but there's definitely a chance that third-party magnetic straps can damage your device.
