08-25-2017
05:46
09:26
08-25-2017
05:46
09:26
All of a sudden this morning my Fitbit will not sync with my iPhone 6.
It worked last night but not now.
My phone can't even seem to connect to it.
HELP!!!!!
08-25-2017 14:21
08-25-2017 14:21
I went on a live chat with Fitbit and this solution worked....
- Connect your Fitbit Charge 2 to its charger, then press and hold the button for 4 seconds or until it shows the Fitbit icon.
- Logout from your FitBit App on your Iphone and turn off your mobile device for 10 seconds then back on.
- Log back into your Fitbit App and this will initialize a sync while the tracker is beside the phone.
08-25-2017 05:49
08-25-2017 05:49
I am having the same problem. I have tried all of the trouble shooting tips given in the help section.
08-25-2017 14:21
08-25-2017 14:21
08-27-2017 10:07
08-27-2017 10:07
@amw78 @CoachLisa23 It's great to have you here!
@amw78 happy to hear that the support team was able to resolve your issue and thank you so much for sharing what worked for you as this may help other members in the same situation.
@CoachLisa23 are you still having issues with your tracker? Have you tried @amw78 suggestions? Could you add more information like the phone you are using and the last time your tracker synced? For how long have you been using your tracker?
I look forward to your reply.
08-27-2017 12:17
08-27-2017 12:17
Worked for me on the second try
05-01-2018 08:23
05-01-2018 08:23
Thank you so much this has worked for me now - had to do it 2 times - the first time I took my Fitbit out of the holder - the second time I left it in and it worked a dream.
05-03-2018 09:01
05-03-2018 09:01
@SunsetRunner A warm welcome to our Community! Happy to hear that you found the solution to your issue in this thread, this is what the Community is all about! If you have the time feel free to check our Community's discussion area where you can find friends to compete with, healthy meals recipes and tips for your daily activity.
I'll be around!
05-03-2018 12:50
05-03-2018 12:50
Thank you. This worked!
06-27-2018 06:38
06-27-2018 06:38
That did not work for me. “Connection Unsuccessful” and a prompt to be sure charge 2 is turned on.
It works fine with iPad Pro.
It worked for awhile when I first got the Charge 2 Fitbit with my iPhone. I’ve updated everything, turned everything off and back on, reset, etc. Occastionally it connects for a few seconds.
All my other Bluetooth devices connect and function well.
06-27-2018 06:52
06-27-2018 06:52
Tried twice. Didn’t work. Works fine with iPad Pro but not with iPhone. Worked for awhile when I first purchased it last month, then quit working.
All other devices pair with iPhone without issue.
07-04-2018 23:20
07-04-2018 23:20
Didn’t work, not happy and fed up.
07-05-2018 04:21
07-05-2018 04:21
It works with my iPad but not iPhone. Looking at the complaints on this forum, this issue has been going on for awhile.
Must be an iPhone issue.
07-10-2018 10:11
07-10-2018 10:11
@Merc2723 @nelliebarr A warm welcome to our Community! Sorry to hear about your Charge 2 not syncing with your iPhone. Try going to your iPhone's bluetooth settings and remove all devices listed there. Restart your phone and restart your Charge 2 by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Make sure all other devices are either away or turned off (bluetooth headphones, iPad or phones that also sync with your Charge 2). Another thing that can help is if you remove the Charge 2 from your iPad bluetooth settings too so it can freely sync with your iPhone.
Let me know how it goes!
03-28-2020 10:52
03-28-2020 10:52
I have tried all the sync suggestions and still won’t sync. Just happened after I updated to iOS 13.4
03-28-2020 10:56
03-28-2020 10:56
03-28-2020 11:04
03-28-2020 11:04
05-23-2020 13:26
05-23-2020 13:26
I have tried The best response over 5 times. It worked the 1st day then it wouldn’t sync the 2nd day
05-23-2020 13:34
05-23-2020 13:34
10-24-2020 19:00
10-24-2020 19:00
Tried this 3 times. Still not syncing with my iPhone
10-24-2020 22:16
10-24-2020 22:16
Not working for me either. I've updated my iphone, and followed the suggested process multiple times.
