05-21-2021
12:37
04:05
WilsonFitbit
05-21-2021
12:37
04:05
WilsonFitbit
Over the past few moths, my Charge 3 screen has become more and more dim. I can’t read it when I’m outside at all. Inside, it’s barely readable. All other functions work. I have completed all the troubleshooting steps. This seems to be a common problem. Can you help?
Moderator edit: subject for clarity/format
05-21-2021
14:38
20:40
EstuardoFitbit
05-21-2021
14:38
20:40
EstuardoFitbit
All the other fun nations work except Country Fitbit.
Have you checked you are not in Sleep Mode?
Hello @Runes. Welcome to the community forums. @JohnnyRow It's nice to see you around and thanks for your input.
Thank you for the detailed information and for letting us know that you've completed all the troubleshooting steps. I also appreciate your feedback and I'd like to let you know that there are other threads with a similar topic, but as mentioned on the post above, make sure that your Charge 3 isn't in Sleep Mode. When the sleep mode setting is on:
To change this, press and hold the button and swipe left to access the quick settings screen. Tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it. For more information, see How do I navigate my Fitbit device?
If that is not he case, make sure that the Brightness setting on your Charge 3 is set correctly. This can be adjusted in the Settings App on your Charge 3. Lastly, make sure that you've also completed these troubleshooting steps from this thread.
See you around.
