10-30-2018
21:42
15:03
10-30-2018
21:42
15:03
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
08-29-2019 13:58
08-29-2019 13:58
Great news @SunsetRunner. I'm glad to hear you already received a replacement. 😊
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted.
Best Answer08-29-2019 16:32
08-29-2019 16:32
My wife had purchased me the Fitbit Charge 3 this last holiday season which worked for under 2 months before pretty much dying. Last syncing was Feb. 25th and still won't sync, Bluetooth devices cannot find it, the almost permanent black screen with a smiley face here and there. I tried all the
'so-called solutions" for several weeks before finally giving up.
After not wearing it for the past 6 months, the wife finally noticed and questioned why I haven't had it on, therefore I am back to trying "solutions" in hopes of a different result. I have been unable to get any result different than my prior attempts. Please help.
Thanks,
08-29-2019 20:15
08-29-2019 20:15
Best Answer08-30-2019 00:04
08-30-2019 00:04
I tried everything with no success. I now have a new watch which after a week is still working. My advise us to contact Fitbit and get a replacement
Best Answer08-30-2019 00:57
08-30-2019 00:57
From the amount of failures with the Charge 3 there does seem to be an inherent issue with it. Not had a reply from the Support Team or the Development section of Fitbit when I made that comment.
Best Answer08-30-2019 09:52
08-30-2019 09:52
Best Answer09-02-2019 10:24
09-02-2019 10:24
Thanks worked for me!
Best Answer09-29-2019 23:54
09-29-2019 23:54
Im facing the same problem.
I have put it on change and pressed the button. It's only buzzing with a green light on behind.
Please help
Best Answer09-30-2019 04:58 - last edited on 02-13-2020 17:11 by LiliyaFitbit
A well published workaround is to sync the fitbit to your phone. Then change the clock face - to anything. Sync again and the clock will return. Then sync again and set the clock back to the one you want.
Best Answer10-16-2019 03:52
10-16-2019 03:52
Hi,
I have tried both the reset (while charging) and the change clock face suggestions, but neither has provided a resolution to the screen having lines on it and device therefore unusable
Are there any other options or what are the next steps for getting this fixed?
Any help appriciated
Cheers
Best Answer10-16-2019 18:46
10-16-2019 18:46
Best Answer10-21-2019 17:20
10-21-2019 17:20
Best Answer11-01-2019 02:32
11-01-2019 02:32
Thanks for very helpful answer! I can now see my screen.
Best Answer11-01-2019 02:58
11-01-2019 02:58
Mine died today 1st November. Just a blank screen all day. I’ve tried all the suggestions and I can manage the smiling face but then it just goes blank again.
Pretty frustrating. Not syncing or showing up in Bluetooth either.
I’m on iOS
Best Answer11-02-2019 01:54
11-02-2019 01:54
Try pressing the button for long. I think I had to press it for at least a minute, perhaps more. Good luck!
Best Answer11-13-2019 13:04
11-13-2019 13:04
I have a Samsung A50. My screen does not work, but fit bit vibrates. Help me please! I have held side button for 21 seconds and still nothing. It was working fine before that.
Best Answer11-13-2019 17:57
11-13-2019 17:57
Best Answer11-24-2019 07:48
11-24-2019 07:48
I've have had my Fitbit charge 3 for almost 2 years and it doesn't lite up anymore...no green light or sensors or LCD screen...only vibration I've tried every possible suggestion x5 times at least. Restarted it, factory reset, changing face clock and nothing worked....does the light bulb burn out cause I think that happened a couple weeks again it wasn't as s bright as normal? Someone please help my fitness is so off track now it been two weeks ...I just moved and can't really afford a new one right now?
11-24-2019 17:03
11-24-2019 17:03
Best Answer12-03-2019 11:37
12-03-2019 11:37
Thank you!!!!! Mine is working again.
