10-08-2017
13:01
09:26
10-08-2017
13:01
09:26
When I don't wear my Charge2 for awhile the green lights on the underside never go off. Is this normal? If not can turn them off. I'm very sensitive to light when trying to sleep.
10-08-2017 13:53
10-08-2017 13:53
r.b. wrote: If not can turn them off.
Here is how you turn them off
https://help.fitbit.com/articles/en_US/Help_article/1565/
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
10-08-2017 13:53
10-08-2017 13:53
10-09-2017 07:37 - edited 10-09-2017 07:38
Hello my friends @r.b. and @ACG, it's nice to see you both here. ![]()
Since this post is about the Charge 2, I've moved it from Charge HR to the right board to keep the forums organized. @r.b. thank you for marking @ACG's post as the solution, marking posts as solutions is a great way of thanking another Community member while also highlighting their solution so that it may be discovered more easily by other Community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more, give it a look!
@ACG it's always awesome to see you around!
Keep up the super stepping! ![]()
What's for breakfast?Check others recipes and share yours!
Best Answer01-01-2019 22:28
01-01-2019 22:28
The link in the accepted answer goes to a generic FAQ page, and does not answer the question.
01-02-2019 06:41
01-02-2019 06:41
Hey @KathyInMonterey, welcome aboard! If you'd like to turn off the green lights on the back of your Charge 2, please follow these instructions:
Hope that helps!
Best Answer07-14-2020 09:44
07-14-2020 09:44
I’ve tried all the steps suggested and even turned off the heart rate. The green
plight stays on and drains the battery in less than 30 mi jets.
other ideas?
08-02-2020 13:56
08-02-2020 13:56
I am having the same problem, just started a couple days ago. Can’t find a solution.
08-20-2020 13:28
08-20-2020 13:28
Same for me. Feels like a bug in the latest firmware upgrade. My firmware version is 22.22.58.0.
Best Answer09-25-2020 06:36
09-25-2020 06:36
Yes! We’re having the same problem. Just started last week. This Charge 2 has worked perfectly for nearly three years until then.
