10-07-2018 04:52 - last edited on 11-17-2020 15:47 by MatthewFitbit
Ok first workout and I can't end it, pressing the button only pauses it. Holding it only brings up a notification and screen wake-up menu?
Moderator Edit: Updated Subject for Clarity
10-09-2018 09:51 - edited 10-09-2018 09:52
@SunsetRunner @obuzzwan @vee I hope you're doing well! Thanks for taking the time to post your exercise tracking experiences with Charge 3 on this thread. Also, thanks for sharing the solution on how to end/finish an exercise and sharing the user manual too.
I will leave a step by step here on how to track exercise for other users to benefit from this as well:
Note: If the Exercise uses GPS, you'll see a phone icon in the top left as your tracker connects to your phone's GPS sensors. When the screen says "connected" and Charge 3 vibrates, GPS is connected.
Hope this helps. Keep me posted!
10-07-2018 11:39 - edited 10-07-2018 12:05
I had the same problem.. kept pushing and tapping...finally saw that it was paused and the next push stopped it. Will be looking for more clarity on this! Right now I think you just have to hold the button down a bit longer, and tapping doesn't work.
Update, I found the manual under the help section. It says one push to pause and another to stop. I think I was doing too much swiping and tapping.
https://staticcs.fitbit.com/content/assets/help/manuals/manual_charge_3_en_US.pdf
10-07-2018 17:44
10-07-2018 17:44
Yes, drove me crazy trying to end my rowing machine workout. It’ll take some getting used to for sure.
10-09-2018 11:49
10-09-2018 11:49
Santi, I had another problem. I got it paused with the one press, but when I pushed the button again I got another screen. Not the one that has finish. Again, it took several pushes to get the finish.
" When you're done with your workout or want to pause, press the button. Press the button again and tap Finish to end the workout."
I wish the button were a little higher up, not right next to the skin, it's a little hard to push.
10-15-2018 13:42
10-15-2018 13:42
In my opinion, this user experience is much poorer than charge 2.
To start an exercise you have to tap 'start' which has a play icon. However, this doesn't actually start the exercise, it just takes you to the 'start' mode, where you tap another play icon. Why the need to create another 'start' submenu and why on earth use the same icon.
Finishing the mode is just as bad. Previously I could do a long press to turn the mode off without even looking. Now you have to push the button twice and then tap finish. After a long run do really want to be fiddling like that? I can't believe you put such a clunky interface out. You can see why people are having a hard time turning exercise on and off.
I really hope you reevaluate your UI design.
10-24-2018 09:52
10-24-2018 09:52
Pushing twice doesn’t work for me. It just resumes the work out.
10-28-2018 09:00
10-28-2018 09:00
yeah, I love my Charge 3 but ending an exercise is so annoying!! button..tap..button again... or something like that! Half the time nothing happens, or it resumes. I do not like how low the side button is. And yes, is this what I want to be doing at the end of my run? (especially since I have a Garmin on the other wrist! At least that is easy!) Does anyone in charge at Fitbit read these messages, or do we have to go to another place to input suggestions?
10-28-2018 09:29
10-28-2018 09:29
11-23-2018 10:06
11-23-2018 10:06
When you say button can you specify the physical button on the side of the watch or the screen (radio) button on the screen.
Getting to the screen which ends an activity is random and intermittent. It is rubbish compared to the fitbit charge 2 and I wish I had that back now
11-23-2018 10:08
11-23-2018 10:08
Getting to the screen which ends an activity is random and intermittent. It is rubbish compared to the fit bit charge 2 and I wish I had that back now
11-23-2018 13:52
11-23-2018 13:52
Still does not end exercise. Tried everything....I think I have a malfunctioning Fitbit. So frustrated!
11-23-2018 14:55
11-23-2018 14:55
Thank you so much!!! I just finished my walk outside over 6.25 miles and I couldn’t shut it off when I was done. You are an angel and I printed it out so now I have a copy Thank you again
11-29-2018 10:14
11-29-2018 10:14
When you say in step 6 When you're done with your workout or want to pause, press the button?
What button? Press the left side of the fitbit "covering" "partially covering" "putting fingernail inside indentation" ?
Not stopping! I've tried all of the above.
12-05-2018 09:29
12-05-2018 09:29
I had difficulty with this myself yesterday when I tried an 'exercise' for the first time on my new Charge 3. Reading the directions in the manual (reproduced as a solution here) didn't help. It turns out that when I 'press the button' I was pressing too long/hard though I thought it was just a press and was taken to a 'settings' instead of a finish/pause. After many, many tries I finally got the press brief enough to get a chance to 'pause' and then 'finish'. I might have realized what was going wrong a lot sooner if the manual mentioned the 'settings' page for 'Wake Screen' / 'Notifications' when you press a bit longer.
12-16-2018 06:11
12-16-2018 06:11
Button? This is a user experience #fail
fix it
12-31-2018 00:32
12-31-2018 00:32
Glad I learned today that I can still return this watch to Amazon - IMO, it isn't intuitive (really, I need to Google how to turn off the exercise?), the clock faces are ridiculous.....etc. Bye, bye Charge 3. Hello Garmin.
12-31-2018 14:26
12-31-2018 14:26
Sorry what is “the button” ? Is that the thing on the left? I have pressed that over and over and I cannot stop my workout. My work around is that I go in to the app and change the screen layout and that seems to stop the workout also. This is really annoying.
12-31-2018 15:16
12-31-2018 15:16
01-01-2019 15:24
01-01-2019 15:24
Agreed, terrible! i hit the play icon the first time and started running. but wait - wasn’t tracking! oh, so i have to host start again? oh why? finishing the workout was so frustrating, the second tap did not work for me, like another user said, another screen popped up, i was so confused. i don’t know how i was able to finally stop it. i liked the exercise function on the first Charge HR the best, no cycling thro gg workouts, just hold button and go. if FitBit really knew their core customers, they’d know we just want to get on with the exercise. PLEASE simplify!
