03-08-2017
15:48
09:49
03-08-2017
15:48
09:49
After having my charge two for a week, the part of the band that attaches to the actual Fitbit broke. I got a new one, but it broke in the exact same exact spot. Would my warranty still cover another one since I just got it replaced? And what can I do to stop this from happening? It hasn't even been a month since I've purchased it and only seems to last a week before the wristband breaks.
08-08-2017 14:01
08-08-2017 14:01
I'm on my third wristband in 7 months...it is the plastic piece that holds band to watch that keeps breaking...I just bought a leather band that has steel instead of plastic ... hoping it corrects the problem!
08-18-2017 08:00
08-18-2017 08:00
My lavendar band has also broken in the same spot 2 times since purchase in February. I just called customer support and they flatly refuse to either upgrade me to a leather band or extend the band warranty. I fully expect to have another broken band in the next 4 months and hope my warranty is not expired by the time it breaks. I too am losing faith in Fitbit and do not expect to continue doing business with this company once the warranty expires.
09-11-2017 22:20
09-11-2017 22:20
09-19-2017 11:25
09-19-2017 11:25
How exactly did you do to get them to replace it with a leather band?! I bought mine in November 2016, had a band replaced in April 2017 and now my band has broke again! Any suggestions? FitBit is being extremely difficult to work with this time around.
09-19-2017 12:08
09-19-2017 12:08
I'll keep this simple as I keep getting these removed! Persistence. Ask to speak to a manager, explain it's a faulty product, the leather is sturdier but still breaks but does last longer. Mine is a charge 2 and I called the UK customer service.
Good luck (I've had 4 break so not a great product)
09-19-2017 12:58
09-19-2017 12:58
I have the same problem! Kin of disappointing. Did customer service offer a refund?
09-19-2017 13:14
09-19-2017 13:14
Flatly refused. I await to see what happens when the year warranty expires
09-19-2017 14:02
09-19-2017 14:02
09-20-2017 07:00
09-20-2017 07:00
if you are in Canada they will not give you a leather band, they will however if you persist and ask for a supervisor get a sports band, so far the sports band has held up I hope it keeps on doing so as my warrentee runs out in December
09-20-2017 07:01
09-20-2017 07:01
customer service will only give you a new band
09-20-2017 07:02
09-20-2017 07:02
they will not give you a leather band however they may give you a sports band if you keep on at them
09-20-2017 07:03
09-20-2017 07:03
@JeanH57 wrote:My lavendar band has also broken in the same spot 2 times since purchase in February. I just called customer support and they flatly refuse to either upgrade me to a leather band or extend the band warranty. I fully expect to have another broken band in the next 4 months and hope my warranty is not expired by the time it breaks. I too am losing faith in Fitbit and do not expect to continue doing business with this company once the warranty expires.
ask them to give you a sports band
09-20-2017 07:03
09-20-2017 07:03
09-20-2017 07:03
09-20-2017 07:03
@Mjlbj wrote:I'm on my third wristband in 7 months...it is the plastic piece that holds band to watch that keeps breaking...I just bought a leather band that has steel instead of plastic ... hoping it corrects the problem!
let us know if that worked for you please
09-20-2017 07:07
09-20-2017 07:07
09-20-2017 07:08
09-20-2017 07:08
Hi Rozeelee - I'm on my second Leather one.. Last a little longer but unfortunately its still screwed into plastic so the same issue
x
09-20-2017 07:08
09-20-2017 07:08
09-20-2017 07:23
09-20-2017 07:23
I love FitBIt, mainly for the users, not necessarily for the product as much. I have the Charge 2 and I like it because it is a vastly improved product over the first Charge, and they actually listened to the customer. Kudos to Fitbit for that.
But with that, I know the trackers themselves are pretty good, but the bands have always been a problem. I have always thought of them as disposable. So with my Charge 2, I used it with the expectation that the stock band will break on me. So I got myself a Glink replacement band. It is stainless steel mesh with a magnetic clasp. I have had it for 3 days now and it seems to work ok. I am able to adjust the fit on it perfectly. The problem with leather or standard bands, is that you are at the mercy of the spacing of the notched holes. For me, on the stock band, I was between notches and one was too tight and the other was too loose. So with my magnetic one, I can cinch the band as snug as I want.
10-08-2017 15:09
10-08-2017 15:09
I had to buy another band now that’s broken. It’s getting a little crazy I’m angry with fFitbit. I’m sure you can make your product a little better very annoying.
10-13-2017 15:51
10-13-2017 15:51
Mine did the same thing. It really ticks me off! My first band broke with 2-3 months and the replacement I bought only last about 1 month. The quality of these bands suck and make me really mad!!!
