08-02-2018
21:40
18:22
08-02-2018
21:40
18:22
I need help as my Fitbit Charge 2 started flashing between notifications on/off several hours ago. My battery was getting low so I fully charged my Charge 2. It is still flashing on/off. I would really appreciate an answer & solution for this as I love using my Fitbit.
Let me know if any more info is needed.
09-19-2018 15:01
09-19-2018 15:01
I had my Fitbit Charge 2 replaced under an extended warranty purchased thru Amazon.
08-02-2018 23:48
08-02-2018 23:48
That suggests to me that the button on the Charge 2 is stuck (pressing and holding the button turns the notifications on / off)
Try gently wiggling it to see if you can release it.
08-03-2018 08:31
08-03-2018 08:31
I tried for several minutes to wiggle the button with no success. Does anyone else have any suggestions. As of right now I have a completely useless Fitbit Charge 2.
08-14-2018 06:43
08-14-2018 06:43
@Jennif6915 Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Charge 2 isn't working as it should. Besides the suggestions @SteveH shared you can try using compressed air at a distance to see if this clears any debris or dirt in the button area and restart your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Let me know how it goes!
09-19-2018 03:00
09-19-2018 03:00
I’m having the same issue and the above suggestions are not solving the problem. Now just the battery light is showing. Any other suggestions
09-19-2018 15:01
09-19-2018 15:01
10-14-2018 10:01
10-14-2018 10:01
@Kobrien7380 Welcome! Thanks for being part of our Community! Sorry to hear about your issues with your Charge 2 and for the delay in my reply. Thank you for following my suggestions. Since they didn't work please let our Support team know about the issue. I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
@Jennif6915 happy to hear that Amazon replaced your device!
I look forward to your reply!
07-02-2019 11:43
07-02-2019 11:43
No the button is not stuck, in fact if you hold the button down, the Fitbit behaves normally.
07-14-2019 14:17
07-14-2019 14:17
Mine was doing the same. This corrected it Thanks
09-29-2019 06:50
09-29-2019 06:50
This happened to me a few weeks ago. I thought I had messed up the side button causing the Fitbit to go crazy. I tried every suggestion online ... resetting the Fitbit, restarting my phone, reinstalling the Fitbit app, turning Bluetooth on/off, etc. I eventually gave up and left the Fitbit on my dresser for the past week allowng the battery to fully drain. I decided to recharged it yesterday and it’s back to normal! Problem solved! Hope it works for you too!
09-29-2019 06:52
09-29-2019 06:52
Let the battery fully drain on its own and recharge it ... worked for me! I tried all the other suggestions and no success.
09-29-2019 11:15
09-29-2019 11:15
Hi Claudia, mine started malfunctioning (notifications on and off) right now. Quick one, how long does it take to completely drain the device?
Regards
Waylon Ferrandi
09-29-2019 16:42
09-29-2019 16:42
09-29-2019 21:34
09-29-2019 21:34
Thanks so much.
10-12-2019 16:38
10-12-2019 16:38
My charge 2 is having this problem right now - notifications flashing on and off. I've tried restarting the Fitbit, turning my phone and bluetooth off and on, etc. None is working. Any other suggestions, please?
10-12-2019 16:39
10-12-2019 16:39
10-12-2019 19:02
10-12-2019 19:02
10-12-2019 19:04
10-12-2019 19:04
10-13-2019 18:25
10-13-2019 18:25
10-14-2019 00:11
10-14-2019 00:11
I was also facing same issue few days back, when contacted fitbit customer care, they said its malfunctioned and need to replace. but it was out of warranty so kept aside. Few days back I changed again to check the problem, surprisingly it is working fine till date.
