07-11-2017
13:49
09:26
07-11-2017
13:49
09:26
For some reason, the Fitbit dashboard changed today on my Windows phone. It used to show steps as the main display on the top, and then went on down from there to other statistics. Today, it started showing calories as the main display on the top. Calories are probably the last thing I care about. If I do my steps, calories take care of themselves.
Try as I might, I can't figure out what happened or how to change it back. Any ideas? I'm attaching a picture of what it looks like now.
Thats an easy fix just press and hold on the main one and then just move the steps back into the center Ive but never really changed anything
Mine, on android does this everytime i start up the app. It may take up to 4 minutes to straighten out, but today i noticed.that i can edit the dashboard.
Just press the red plus sign.
Best AnswerI tried it again. The first time, it changed and then reverted to calories on top the next time in. But I tried it again, and this time I saw the "Done" link at the bottom. After clicking that, it remained as set the next time in.
Best AnswerI have the exact same problem, I like to see my steps as I know like you the calories take care of themselves. I have deleted the app, disconnected the Bluetooth - forget device, rebooted my phone, there is no option to even find the steps counter on my dashboard as hidden. So using the home button to find it doesn't help, I know how to customerise the screen. Help....
I have also had my dashboard all messed up today. My steps don’t even show up and other items are missing. I’ve managed to “fix” it a couple times then it goes back to messed up. I am hoping Fitbit will fix it overnight. I have got to stop looking at it before I go crazy.
04:22
08:43
03-18-2021
04:22
08:43
@stephen.h It's great to see you in the Community!
If you can try logging out from the app, restart your phone and log back in and make sure it is up to date. If you can't and are on an Android device the go to Settings > Apps > Fitbit and clear the data. If the issue persists then uninstall and reinstall the app.
Hope this helps.
10:16
08:40
03-18-2021
10:16
08:40
@stephen.h happy to hear that! And thank you for letting me know as this does help monitor the problem and any possible fixes applied to it.
Happy stepping and stay safe!
