09-17-2016
15:45
10:26
09-17-2016
15:45
10:26
Just got my Charge 2 a few days, but it seems to me that the Quick View feature doesn't always works perfectly. Other people having the same problem? It does work approx. 7 times on 10...
08-17-2017 09:13
08-17-2017 09:13
I just tried this and it drained my Battery!! I hope it can recharge.
Best Answer08-31-2017 06:35
08-31-2017 06:35
Did not work
Best Answer09-04-2017 09:19
09-04-2017 09:19
The time on devise is not correct and I cannot reset the time. Any suggestions? I've tried turning the devise off and changing time zones. The devise will not sync with computer or phone.
Best Answer09-04-2017 12:37
09-04-2017 12:37
Best Answer09-05-2017 10:30
09-05-2017 10:30
@Dscan make sure your Charge 2 has quickview on, do a restart.
Now take it off your arm and place it on a table facing you you. Lift up the far end so that the Charge 2 is now vertical.
09-21-2017 14:51
09-21-2017 14:51
The flit charges to 100% but has discharged to 15% within an hour. I have tried to reset it three times but the same happens
Best Answer09-24-2017 12:00
09-24-2017 12:00
I tried this, it didn't work
Best Answer09-24-2017 12:03
09-24-2017 12:03
didnt work
Best Answer10-01-2017 18:58
10-01-2017 18:58
I tried this method. It restarted but the date and time did not change. Vacationed in Alaska and cannot get the Charge 2 to return to normal. It is stuck on 9/22/17, 5.5 hours behind. Any advice?
Best Answer10-01-2017 19:04
10-01-2017 19:04
Best Answer11-02-2017 09:46
11-02-2017 09:46
I just tried to reset my charge 2 but when I had it plugged in and pushed the button, all I got was initially the picture of the batter and never the Fitbit log. I am having a problem with my Fitbit not receiving notification or recording get the heart rate on my iPhone 6plus. I get the resting heart rate but above it I have two diashes. When I check my phone settings it does say it is connected to my blue tooth. The Fitbit does sync to my iPhone and in fact the heart rate is recorded in the daily graph and shows on the fit bit itself. When I tired to set the notifications it still says Bluetooth pairing required and when I push ‘set up’ I even tried disconnected this Fitbit from the system and reinstalling but it made no difference. This is my 3 Fitbit is I am aware how it all should work. I think I have had this one a month and bought it through you. Any suggestions would be much appreciated. I really find it useful having it viberate when I receive a phone call because I do not always hear the phone. Thanks Malvene
Best Answer11-02-2017 09:47
11-02-2017 09:47
Best Answer01-18-2018 04:44
01-18-2018 04:44
Having restarted my fitbit it now won't reconnect to Bluetooth due to incorrect parsley. What is this? How do I solve it I've also uninstalled and reinstalled the app on my phone.
Best Answer01-23-2018 13:04
01-23-2018 13:04
Mine stopped working and takes quite a few taps now to see screen data etc
now it’s acting up by not syncing snd now now recognise my phone ??
Best Answer01-23-2018 13:06
01-23-2018 13:06
I’m having the same problem !!! Have u managed to get it sorted ?
01-23-2018 13:06
Best Answer01-23-2018 13:13
01-23-2018 13:13
Best Answer01-23-2018 13:24
01-23-2018 13:24
I tried everything you suggested. My display has totally gone out. I can see on the back side the lights are on showing the Fitbit works. I am so sad this was a gift from my daughter and I did not even get a year out of it. I really enjoyed using it and the self encouragement to get moving and get my steps in. I am afraid it is gone
Best Answer01-23-2018 14:04
01-23-2018 14:04
Best Answer01-23-2018 14:48
01-23-2018 14:48
