11-27-2017
21:15
18:54
11-27-2017
21:15
18:54
Large crack in my Fitbit charge 2 , can I purchase a replacement glass.
06-21-2020 11:04
06-21-2020 11:04
Best Answer06-21-2020 11:08
06-21-2020 11:08
My Fitbit Charge 2 screen is badly scratched. Can the screen be replaced?
Best Answer06-21-2020 11:19
06-21-2020 11:19
My guess is your screen is cracked and not scratched. If it is cracked and under warranty, Fitbit will replace the watch. If it is scratched or out of warranty you are out of luck. Just the screen can not be replaced.
06-22-2020 10:15
06-22-2020 10:15
I have been a Fitbit owner since the FitBit Charge HR came out and was very happy until the integrated band broke and their solution was "Hey will give you a discount on the new FitBit Charge 2" which I only took because it had a removable band. It is disappointing that FitBit did not learn from the integrated band fiasco of the Fitbit Charge HR. The cover is not glass it is plastic and user serviceable but FitBit customer service is really the sales department as they are more interested selling you a whole new unit then making customers happy. I will try gluing this plastic face to give the unit a little more time since the unit works flawlessly other then the cheap plastic face they put on it which it seems they carried forward based on some of the other posts I read. I'll keep an eye out for a broke Fitbit Charge 2 with a non-broken plastic cover. Anyone know a site to buy an after market replacement cover for FitBit Charge 2? I started with a Fitbit Charge HR and then got an Apple Watch and ran both eco systems for quite a while but after this I guess I will stick with my Apple Watch when this FitBit Charge 2 finally goes.
Best Answer06-22-2020 11:16
06-22-2020 11:16
Best Answer06-22-2020 13:30
06-22-2020 13:30
It is my understanding that screen can't be replaced
Best Answer06-22-2020 13:57
06-23-2020 06:49
06-23-2020 06:49
What this video says is that the screen can be replaced but Fitbit just had decided that they would rather require their customers to buy a new watch than to fix the design flaw that they created. Just another reason that Fitbit has a lot of work to do and we can only hope that Google will make changes in the future. For me the Charge 2 issue is a past problem that I want to forget.
Best Answer08-24-2020 00:53
08-24-2020 00:53
I want replace my fitbit charge 2 display. Because its not working. So please help me.
09:15
09:08
09-01-2020
09:15
09:08
@alke0812 Thanks for stopping by!
Let me help you with your Charge 2 screen not working. The screen can't be replaced but I would like to know if you have troubleshooted this issue. If you haven't then please restart your tracker by following these instructions.
I look forward to your reply.
Best Answer01-12-2021 12:45
01-12-2021 12:45
How do I ho about getting hold of the support centre I have damaged my screen on my charge 2 but can't seem to find the email address. I live in South Africa if someone could assist it will be great please.
Best Answer01-12-2021 12:59
01-12-2021 12:59
Login to Fitbit.com and then click on your account and then click on your account picture. Down at the very bottom you will find HELP. If you follow the links for your Charge 2, you should be able to at least email or chat with them. That being said, if you are out of warranty you are out of luck and will need to live with it or purchase a new watch of some brand. There is a flaw in the Charge 2 where the screen cracks from the top to the bottom and Fitbit says the screen is not replaceable. Some say it is, but I have never seen the parts to do the repair.
Best Answer01-12-2021 14:12
01-12-2021 14:12
Best Answer01-12-2021 14:23
01-12-2021 14:23
