09-07-2019
12:39
10:43
09-07-2019
12:39
10:43
Anyone else having this problem? My Fitbit was syncing just fine a couple of weeks ago. My phone did have an update which I didn’t update right away but it has suddenly stopped syncing up. So I updated my phone thinking that was it but no. Checked that my app was up to date which it was and have contacted customer support only to be ignored and I’m getting super frustrated. It literally worked two weeks ago. I’m now reaching out on Facebook to try to get answers but this is just eye roll worthy. Help!
09-11-2019 14:16
09-11-2019 14:16
I've done every clear, reboot, etc but still nothing synching. Also I can't get the clock on the correct time.
09-11-2019 14:18
09-11-2019 14:18
I'm having the same issues! Won't synch and time is way off.
09-11-2019 15:23
09-11-2019 15:23
yes. mine was syncing ok upto 31st august, and since then wont sync, time wrong, tried re booting and everything fit bit has suggested on this site.
09-11-2019 17:54
09-11-2019 17:54
09-11-2019 18:57
09-11-2019 18:57
My time was off too.
I deleted the app, rebooted the factory reset, installed the app and now it's working fine.
09-11-2019 20:53
09-11-2019 20:53
09-12-2019 06:07
09-12-2019 06:07
I've been having the same problems for the past few days. This is so frustrating!
09-12-2019 06:15
09-12-2019 06:15
09-12-2019 14:03
09-12-2019 14:03
I called today and I was told that they are aware that this is giving issues to certain iOS users.
I was told to put the Fitbit on the charger to have it charged for a reset. While its being charged, press the button the side for 10 sec (until you see the happy face) then release. When it turned back on, I went to the Fitbit app and was asked to repair it to the Bluetooth. It did and it synced nicely. It’s been stable since then.
09-12-2019 16:04
09-12-2019 16:04
Same here!
Texts no longer sync....etc...
This latest update is just horrible. I hate the way the dashboard looks...it looks so uninspiring and bland.
Is this so we will purchase the new ‘premium’ upgrade??
09-12-2019 17:48
09-12-2019 17:48
09-12-2019 17:56
09-12-2019 17:56
Mine just randomly started working and also somehow had all my data back to when it stopped syncing. This tells me it was the app and not the Fitbit charge3
09-12-2019 18:14
09-12-2019 18:14
09-13-2019 11:10
09-13-2019 11:10
Hello everyone.
I am sorry to hear that you are going through this situation. I appreciate your feedback and efforts in troubleshooting your Charge 3 devices.
As some of you have been informed after contacting our Support Team, please note that our team is still researching the most accurate resolution for this ongoing issue.
However, we don't have a time frame at the moment when this issue will be resolved.
We recommend to remain attentive to upcoming Fitbit app updates in the meantime. We appreciate your patience, and look forward to get you back on track.
Let me know if you have any questions present.
09-13-2019 22:32
09-13-2019 22:32
09-14-2019 00:11
09-14-2019 00:11
09-14-2019 04:54
09-14-2019 04:54
For me. I reset watch while it was charging once you see smily face all is good. It seemed to start working properly then. I has an issue with not seeing heart rate on dashboard but I fixed that by going into the settings on app and clicking notifications and setting them on. Reason they were off in first place as I had uninstalled and reinstalled and looks like they were defaulted to off. Anyway I’m sorted and hope you’re all sorted soon.
09-14-2019 07:45
09-14-2019 07:45
09-14-2019 12:30
09-14-2019 12:30
09-14-2019 13:09
09-14-2019 13:09
