01-04-2016
11:07
20:42
01-04-2016
11:07
20:42
I have been using my Fitbit Charge HR for a couple of weeks now, and while I am finding so many aspects beneficial I have been encountering issues with accuracy regarding treadmill workouts.
Both step count and mileage in grossly under reported by my Fitbit, for instance today I did 3.83 miles of inclined walking and my Fitbit only recorded 5,608 steps and 2.4 miles. I do not hold on to the rails at any point in my workouts and my arms swing naturally. Every workout I've had on the treadmill I have had to delete the entry and manually enter the correct distance values, which then updates the step count. It is winter in new England and not many brave souls are out logging miles in freezing conditions, I use my treadmill daily for workouts.
However, now I do not get credit for my manually enetered steps for daily challenges or badges.
How can this Fitbit be so innacurate on both distance and step count on one of the most common methods of excercise?
The Charge 2 is still attached to the arm, and even in treadmill mode, this is run mode with no gps, the tracker still needs to see arm movement for it to think the legs are moving.
Yes when the speed of the run is changed, the users stride also changed. Figure an average stride.
Best AnswerLpawlik-How did the customer service correct the device issue when you called them?
I could never get correct steps nor miles for treadmill after trying all the things people suggested here. I have simply given up!
Best Answer@IleanaM let's go to fitbit's searchable interactive help guides, link is found below as Help.
We will find two articles
How to track an exercise with Fitbit
How do I use exercise apps and modes on my Fitbit device?
In this article is a link to
Best AnswerI had that same problem with excessive flights on a charge hr and it was a device problem. Call Fitbit customer service. If your registered device is still under manufacturer warranty they should send you a new one. If you bought an extended warranty that should replace it.
i had three device failures with a charge hr but have had no device failures in the 7 months i have used a charge 2. I think the charge hr’s design of the mechanism being spread over the face AND the band caused a lot of device failures. The charge 2’s mechanicals are solely contained within the device not the swapable band and at least for me has been much more reliable.
Best AnswerFYI: I thought I would share something I figured out. I was having the same issues with the treadmill and it not tracking the steps. I've figured out that you can track the steps on the treadmill and the elliptical. On the tracker push the side button until you come to walk, tap the tracker until you get whatever you want to do up and then hold the side button until it starts. Make sure your ready to go because it starts immediately. When you're done hold the side button on the tracker until it says finished. You have now logged your workout whatever it might be. Charge 2 is really good once you figure out all it has to offer.
11:46
05:06
JuanJoFitbit
01-23-2018
11:46
05:06
JuanJoFitbit
Me as well. Very frustrating.
I have the Surge-$250!
Moderator edit: merged reply
Best Answer@malvargo if you click on the word "help" found at the bottom of this, or any, page., then tap your tracker. You will find a link to your manual.. Your also in fitbit's interactive searchable online help docs.
