04-13-2019
12:08
11:12
AndreaFitbit
04-13-2019
12:08
11:12
AndreaFitbit
It still vibrates when I hit the button. I saw the smile once but haven't seen it since and nothing is working. Very frustrating given its only 2 weeks old. Is there a solution or hard reset?
Moderator Edit: updated subject for clarity.
03-13-2020 10:54
03-13-2020 10:54
Same as me theres just a line in the middle of screen
03-16-2020 18:29
03-16-2020 18:29
My Inspire HR just had this problem with the screen going black for the second time. First time on 2-7-20, and second time today on 3-16-20. Changing the screen display via the app worked just like last time, but it is annoying that they can't fix this common glitch.
03-22-2020 02:35
03-22-2020 02:35
I can’t see ant response to this problem- I am trying to activate all ok expect I can’t see anything g data has synced with my phone so working just will it display on inspire
03-22-2020 03:40
03-22-2020 03:40
Hi, @McMahons , have you tried giving your Fitbit a restart? That can often solve this issue. Here are the instructions:
Sometimes you need to hold the button for longer than the recommended 5 seconds, and do make sure that there is good contact with the charging points, as it must be plugged in and charging in order for the restart to work.
Good luck, and let us know how it goes. Welcome to the Community!
03-22-2020 10:05
03-22-2020 10:05
03-22-2020 12:28
03-22-2020 12:28
I purchased a Fitbit hr inspire for my wife in February and the display is not changing it just stays fixed can’t change the display by swiping or pressing the button
03-22-2020 13:40
03-22-2020 13:40
See Julia Gs fix below. It worked for me.
03-26-2020 17:56
03-26-2020 17:56
03-26-2020 19:55
03-26-2020 19:55
04-20-2020 12:37
04-20-2020 12:37
I have a Fitbit Inspire and the face is stuck on the time and the exercise symbol. What can I do
04-20-2020 15:10
04-20-2020 15:10
04-24-2020 04:33
04-24-2020 04:33
Hi,
Faced same issue today.
Although its working again for now.
Steps:
1.connect to band via fitbit app.
2. Change clock face
Volla screen came alive
04-26-2020 01:15
04-26-2020 01:15
None of the above solutions have helped me with my hr inspire. It's still locked on the clock screen and won't respond to touch.
05-01-2020 12:54
05-01-2020 12:54
I am having the same issue. My first fitbit was replaced last month due to issues. The replacement now has no video!
05-03-2020 08:12
05-03-2020 08:12
I was able to fix it with a restart.
05-25-2020 18:40
05-25-2020 18:40
My inspire hr will not show displays. I have reset it 3 times. I have had it for a month
05-26-2020 00:16
05-26-2020 00:16
05-26-2020 06:14
05-26-2020 06:14
effected my HR to!!
05-26-2020
06:55
03:56
05-26-2020
06:55
03:56
If your Inspire HR display is not working, the advice is to try the restart procedure:
Plug it in to charge in the usual way using a charging plug known to be working. A CE/UL certified wall charger is fine. Make sure the charging points are lined up. If yiu are not certain that it is well chaged, give it a couple of hours plugged in.
Once you are sure it is well charged (even if it didn’t seem to be charging), while it is still plugged in and charging, press and hold the button. Make sure you do not disturb the contact between the Fitbit and the charging cable - the restart will never work if it is not properly connected.
When it restarts you should feel a slight vibration and see a smiley face icon. If you do not see this at first, repeat the procedure, possibly holding the button for longer.
If it won’t work after tryng the restart at least 3 times, please get in touch with Fitbit on contact.fitbit.com They will definitely ask you to try the restart procedure as a first step, so I would strongly recommend doing this first, even if your Fitbit is only a few weeks or months old, before contacting Fitbit, as that will save everyone’s time.
05-26-2020 13:40
05-26-2020 13:40
