Inspire HR won't sync
ANSWERED
Inspire HR won't sync.... app keeps searching for old Alta HR
My inspire HR is giving me messages, like texts/phone call alert but it won't sync to give me steps from yesterday or today.
Argh!
1 BEST ANSWER
Accepted Solutions
@SusieQB Thanks for stopping by!
Let me help you with this. The Alta HR should not affect your Inspire HR syncing to your phone still you can remove it if you aren't using it anymore by tapping the top left button the the tracker icon and finally the trashcan icon. Regarding the Inspire HR you can try the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Hope this helps.
Alvaro | Community Moderator
6 REPLIES 6
Hope this helps.
Thank you!! That worked for me!
@PatM18 Welcome to the Community.
Glad to hear that my suggestions helped you solve the issue and thank you for confirming this as it may help other members in the same situation.
Happy stepping and stay safe!
I had this same issue this morning as well. I deleted the app and when I went to sign back on it is not letting me in. I tried all they said for it not syncing to no avail and then decided to delete it but I can't even get back in there now.
I didn't delete it from my phone, but I did restart my phone. That didn't help. I did restart my fitbit and charged to 100% now it's working.
@SunsetRunner It's nice to have you on board!
@SusieQB happy to hear that your issue was resolved! @SunsetRunner there was an issue affecting connectivity the date you posted but since then it has been resolved so you should be able to log in and sync your device now.
See you around.
