06-03-2019
10:49
06:26
YojanaFitbit
06-03-2019
10:49
06:26
YojanaFitbit
Inspire only showing time and steps nothing else. Cant swipe up to get miles,sleep,calories and cant hit button on side to see battery percentage
06-04-2019 06:25
06-04-2019 06:25
Nice to see that you're digging into the Forums @Salzkorn, let me give you a warm welcome to our Community.
Thanks for reporting the issues with your Inspire. Please try to restart it with the following steps:
Your tracker should now work normally. If your tracker still doesn't work after a restart please let me know.
I'll be around.
06-04-2019 11:31
06-04-2019 11:31
I'm having the exact same issue, it started last night. Thanks for the tip!
06-05-2019 10:49
06-05-2019 10:49
Nice to see you on the Fitbit Forums @monkychik, welcome!
You're very welcome, we're here to help. Please let me know if you need anything else.
I'll be around.
11-02-2019 16:51
11-02-2019 16:51
I tried this and it did not revive my Inspire HR. It appears the fitness tracker is dead in less than 4 months...
11-02-2019 22:51
11-02-2019 22:51
My Inspire HR is doing the same thing after only 2 mos-will not respond and only showing the clock. Cannot access battery percentage either. Tried restarting it multiple times per guidance above with no luck. Worked just fine the day before.
11-03-2019 00:31
11-03-2019 00:31
Thanks so much! Mine was doing exactly the same and it is now sorted. 🙂
11-03-2019 05:40
11-03-2019 05:40
VERY DISAPPOINTED. I just replaced my One with an Inspire last Sunday. It wouldn't pair with my laptop (it will pair with my Android phone) and the display wouldn't come on unless I pushed the button. I restarted it last Sunday and it would at least come on. Again yesterday, the display quit coming on unless I pushed the button. I tried to restart it with no luck. I tried again today; it restarted and the display works again. Also, I had ordered the stainless steel band, and it would not stay attached so am waiting for Fitbit to send a new one.
12-27-2019 14:49
12-27-2019 14:49
mine does the same thing. i can get battery percentage by holding down the button but we set it up this morning and the touch screen wont respond to swiping.
12-27-2019 14:51
12-27-2019 14:51
i tried that but it didnt work.
12-27-2019 17:27
12-27-2019 17:27
Thanks for this info! I was having the same problem and that fixed it right away.
01-20-2020 14:39 - edited 01-20-2020 14:45
Please delete. I reposted with an updated outcome. Thank you
BTW, love my inspire HR. It doesn't interfere with my other bracelets...
01-20-2020 14:41
01-20-2020 14:41
My wife had same issue with following data points (to help you guys figure this out)...
0. We discovered the problem in the middle of a run (she does not track exercise separately)
1. The reset worked, and
2. The Fitbit app on the S7 phone picked up steps including the run, yay!
3. The inspire HR displayed the steps after 7-10 mins.
01-20-2020 14:56
01-20-2020 14:56
I get the same problem. Followed the advice but it didn't work. I press and hold for five seconds; the display shows the time for three then goes blank. When I stop pressing it doesn't show the smile icon and the problem doesn't go away. Any advice?
01-20-2020 21:56 - edited 02-27-2020 21:47
I had to perform the five (5) second hold a couple of times. Actually, the
third time I probably held it for about seven (7) seconds, but it worked
that time.... Good luck.
02-27-2020 20:12
02-27-2020 20:12
Thanks so much, really helped
04-01-2020 13:26
04-01-2020 13:26
That did the trick. Thank you.
04-08-2020 13:14
04-08-2020 13:14
I am disappointed that your recommended course of action did not get my Inspire to work. It was a Christmas gift. So is there any other remedy?
Ann
04-22-2020 10:35
04-22-2020 10:35
Followed you advice and it worked thank you
04-22-2020 11:17
04-22-2020 11:17
