04-07-2018 11:22
04-07-2018 11:22
First off, the Versa has been terrific. I have had it since Monday afternoon, it made it to last night before needing to go on the charger (with a couple GPS connected exercises included in there), is very comfy, screen is crystal clear all the time even in very bright sun. But I have had a couple things of note:
Has anyone else with a Versa had any minor issues? All my problems have passed or have been resolved now, and I love this watch a ton.
04-07-2018 19:52
04-07-2018 19:52
Hi, I've only had my Versa for about 24 hours. The first problem that I am facing is my app doesn't count my steps in real time as it used to. It did work a little bit this morning when I was on my treadmill but tonight it wont. I have to force a sync.But also this morning as I was on the treadmill, I know I should have active minutes because on my One and Charge 2 would sync and give me an updated active minutes as I went along.But even when I forced a sync it wouldn't update the AM.It finally did when I finished my workout and logged it into another app that syncs with FitBit.
I don't know if I am just looking at things wrong since I have only had the Versa a day.
04-08-2018 16:55
04-08-2018 16:55
I have having similar problems. I can see certain stats on the versa but not on the app. Also can't see sleep.
04-08-2018 17:04
04-08-2018 17:04
Just fixed my problem by disconnecting my Bluetooth, and reconnecting. I also restarted the watch.
Hope this helps 🙂
04-08-2018 18:04
04-08-2018 18:04
It's glad to see that you're already enjoying the Versa.
As far as I understand. It seems the issues are with the Fitbit App itself. The Fitbit Ionic, which runs the same software than the Versa, used to have a lot of syncing issues with Android.
Sometimes the background sync won't work at all, sometimes it will be the only thing that's working, and sometimes it will act as if it were syncing (By sending some info to the app but not everything) but in reality it isn't.
The usual steps (restarting, force closing the app, etc) seem to work but I'm curious to see if in general the Versa does better than the Ionic.
A friend got the Versa and he's using it witha Huawei Lite model (which are supposed to be incompatible according to Fitbit) and so far he said it has been wonderful.
04-11-2018 05:27
04-11-2018 05:27
I am also facing syncing issues since I received the Versa on Monday. Yesterday I had to unpair it from my phone and then repair it, to get it working. I woke up this morning and the syncing is back to not working. I've been turning the Bluetooth on/off and restarting the Versa for the past 20 minutes. Still not syncing.
04-12-2018 18:22
04-12-2018 18:22
I am so glad everyone is having great luck with there Versa. I just wished I was. I received mine on Wednesday and set it up. Everything in set up was great. It was after that it was all down hill.
First the touch screen does not work. I even did a hard reset. Still nothing!
Second called Fitbit and was told to send video of what was happening. Received an email saying they needed a different video not once but 4 different emails and 4 different video. All of the video showed a different screen not working. One full day and I am still waiting for someone to email me back to see what can be done. How about sending me a new one??
Has anyone had this problem? This is not first Fitbit to own. I would have kept my charge 2 but I cracked the screen.
04-12-2018 18:36
04-12-2018 18:36
When in doubt reboot your Versa.
04-12-2018 18:49
04-12-2018 18:49
04-17-2018 11:13
04-17-2018 11:13
whats up with this send a video crap? come on fitbit. if more than a handful of customers are complaining about the same issue, it's the product. I've been holding out on buying a garmin to see what the versa was gonna do but im headed back to best buy for a return. dang on watch wont even charge.
04-17-2018 11:39
04-17-2018 11:39
i tried and nothing. is there a way to factory reset?
@blu-steel wrote:When in doubt reboot your Versa.
04-17-2018 17:41
04-17-2018 17:41
@SandraKay74 wrote:I am so glad everyone is having great luck with there Versa. I just wished I was. I received mine on Wednesday and set it up. Everything in set up was great. It was after that it was all down hill.
I had the exact same problem with the touch screen not working. I saw you and others had to make a video documenting the issue. I was asked to do the same and I flat out refused and am sending the unit back for a refund. Had it less than 24 hours - I shouldn't have to prove and send videos that FitBit sent me a defective watch. It should be an automatic replacement. Poor business practice and policy. They are losing a customer because my next watch will be an Apple after this experience.
04-17-2018 20:20
04-17-2018 20:20
went to bb to exchange, girl plugged in. worked fine on her insignia box (im using fast charger came w note 😎 it worked. went back to my box again, NO GO! WTH? long story short, i ended up buying an insignia box to charge watch. so its $199 PLUS $20.
04-19-2018 12:46
04-19-2018 12:46
So I just got my Fitbit versa yesterday and was so excited until I went for my run and changing the song ended my tracking!? Never had that issue with the Blaze. I even tested it at home walking around the house and every time I changed the song it would either end the workout/exercise or pause it. Anyone else?
04-29-2018 04:34
04-29-2018 04:34
Restart fitbit helped
05-01-2018 07:21
05-01-2018 07:21
Went swimming in pool, put on swim ap with the versa . Water got inside the battery now it won't work at all. No display and won't charge. Completely dead. Had it less th62 weeks already ruined from water getting in it. Has anyone else had this problem?
05-19-2018 01:06
05-19-2018 01:06
Ever since latest update things have gone down hill...
Sleep not capturing every hour
250+ steps screen has to be entered 2x before data shows
Sync hardly ever works
Not impressed .. need to revert to previous software version as that worked
05-19-2018 07:35
05-19-2018 07:35
05-19-2018 11:07
05-19-2018 11:07
05-19-2018 11:54
05-19-2018 11:54
I agee. The process to send the fitbit back to Fitbit is lengthy and ridiculous. When I was going through Fitbit to get a replacement they wanted me to send a video clip of me trying to restart it. And the person helping me said that that step was important to move on to the next step. Then I also had to print out the shipping labels. Fitbit sent confusing instructions about shipping it to them through usps or fedex and the 2 different Fitbit people I talked to gave me wrong information. I also strongly believe that these Fitbit helpers have no idea how their products actually work. You send me instructions for a factory reset to press all 3 buttons while charging in the charger? Come on. Do you even know how the versa charges? If you did, then they should know that is physically impossible. Then the first Fitbit customer service person I talked to kept referring my Versa as an Ionic. After multiple time telling her I have a Versa she still referred it as an Ionic. Geez. Also, If Fitbit pays for your shipping they take the 2 weeks shipping length (not including the length for them shipping it back to you). If you want to get it to them faster, you pay the fedex shipping rate. That to me is ridiculous. I payed $200 for their device that didn’t even last a month, I expect them to quickly send a replacement. It was just a lengthy frustrating experience with them.
