05-22-2018
09:37
07:54
AlvaroFitbit
05-22-2018
09:37
07:54
AlvaroFitbit
Versa special edition, pre-order, paired with Samsung S7edge. Beginning about 3 weeks ago my versa watch suddenly started opening apps on it's own. Here's the example: I press the single left side button to turn on the watch face, then I swipe from right to left to access apps. At first it will have trouble sliding the screen to the apps page so I will have to swipe a few times. Then the apps page will fully appear and without me touching a thing, it will start opening random apps. Usually the exercise one, but there have been others. The exercise app will open. I will push the single left button to try and return to the previous screen. It will return to the apps page and then immediately open the exercise app again. It will not allow me to exit the app page and get back to the clock face.This loop will continue indefinitely until I force it to do a hard reset. This has also happened when I swipe from bottom to top to access the daily stats page. From there it opens the settings page and the vicious loop begins until I manually reset it. This doesn't happen all the time but it is becoming more and more frequent. Has anyone else experienced this? I'm ready to call customer service, I love this watch but paid too much for it to malfunction so often, and being pretty much brand new this is definitely not ok.
05-24-2018 08:19 - edited 06-06-2018 07:20
@JSam Welcome! It's nice to have you on board! Thank you for trying the restart to see if this helps correct the issue. Can you tell if the app that opens is always in the same spot as the exercise one (if you can swipe to a different screen)? Not sure but this sounds as if the screen is being pressed. Could it be that it was hit against something? Still like you said this isn't normal nor expected so the best thing to do is letting our Support team know about the issue so they can assist you. You will get an email from them.
Let me know how it goes!
Best Answer05-24-2018 11:42
05-24-2018 11:42
@AlvaroFitbit Thanks and yes it is always in the same location regardless of which screen it's on. It's really odd. Never been dropped or hit by anything. I baby it pretty well. I don't even get it wet although I know versa can get in the water I don't chance it 🙂 I'll see what support says. Thanks for passing it along to them! I love my watch, but I just need her to behave properly!
06-05-2018 20:58
06-05-2018 20:58
I'm having a similar issue. Did you get any resolution? I've tried changing the clock face and rebooting the device.
06-06-2018 07:38
06-06-2018 07:38
@Lexivore Welcome to the Fitbit Community! I hope you're doing well!
@JSam hope Support was able to help you.
@Lexivore since you already tried the suggested troubleshoots for this issue the best thing to do is letting our Support team know about it so they can review your Versa's information and assist you. You will also get an email from them.
Best Answer09-09-2018 03:18
09-09-2018 03:18
I too have the same issue... I take care of my device pretty well... not even a scratch on it... don’t know why this is happening!!! Please help.. it’s irritating!
09-26-2018 12:12
09-26-2018 12:12
@Praseeja A warm welcome to our Community! Sorry to hear about the issues you are having with your Versa. Try restarting your device by following these instructions. Also clean the button area with compresses air at a distance.
12-15-2018 12:58
12-15-2018 12:58
I am also having screen issues.I have contacted the support team and did the the reset and the cleaning they asked me to do and it still is not working
Best Answer12-15-2018 14:55
12-15-2018 14:55
Mine is not resolved yet... it’s a bit irritating... I hv started to wear it lesser than I used to .
Best Answer12-15-2018 15:17
12-15-2018 15:17
Mine got to the point where I couldn't do anything. The screen would flicker between screens and didn't respond to touch. I ended up having to return it to BestBuy.
Best Answer04-15-2019 01:34
04-15-2019 01:34
Yeah it has just happened to me and have to restart my whole fitbit
Best Answer04-15-2019 02:19
04-15-2019 02:19
I think it is only problem with a few pieces... restarting did not work for me.. I lived with it for a while.. then I just bought an apple watch... its a lot better
Best Answer04-15-2019 10:33
04-15-2019 10:33
My Versa freezes and I have to restart it. I have not had any apps opening
Best Answer07-10-2019 22:38
07-10-2019 22:38
I have the same issue, restarting and resetting is not working for me. I am really frustrated with it doing this!
Best Answer07-21-2019 13:21
07-21-2019 13:21
My verse is flipping between screens on its own. Unable to shut it down. Flips to another screen when I try to go to the shut down app
08:01
09:37
AlvaroFitbit
01-19-2020
08:01
09:37
AlvaroFitbit
My Versa is doing the same thing. It is toggling between stats. I have restarted it and I have shut it down. Since shutting it down the screen now flickers awake every 2 to 3 seconds. Please help.
Moderator edit: format
Best Answer01-23-2020 09:39
01-23-2020 09:39
@ajninasop1 Welcome! It's nice to have you on board! Sorry for the delay in my reply.
Let me help you with your Versa scree not working and thank you for troubleshooting this issue. Since the issue persist please let our Support team know about this. I noticed that you already have a ticket with them so keep working with the team to find a solution.
Let me know how it goes.
Best Answer04-19-2020 08:02
04-19-2020 08:02
My Fitbit Versa was doing the same thing and started at approximately the same time. Now this morning while it worked around an hour ago with medium battery but at this time the screen went black. Now mine isn't responding to a reset.
Best Answer05-18-2020 13:56
05-18-2020 13:56
This has been happening to me for about a week now. Screen stays on most of the time now. If I press the left button to turn it off it comes straight back on. Has used 55% battery in 12 hours (I’ve not tracked any exercise today) it freezes and isn’t counting steps properly
Best Answer05-19-2020 06:38
05-19-2020 06:38
