12-18-2019 08:05
12-18-2019 08:05
When trying to log my daily weight in the Fitbit Today app on my watch, if I put in 164.1, I'll see 361.7 logged in my account. This error has forced me to disregard this feature entirely, and I am considering throwing the device away altogether. It's very demotivating to see such a large incorrect gain
01-24-2020 11:03
01-24-2020 11:03
I’m having this issue on Ionic Fitbit. Log 131 and showing nearly 300! Keeps telling me I have about 160lbs to lose!
Best Answer01-25-2020 07:38
01-25-2020 07:38
If you put it into the app instead of the watch, you get a good reading. For some reason it says that it's using US measurements, but it's recording in Metric and then the phone is doing the conversion the wrong way.
Best Answer01-25-2020 08:07
01-25-2020 08:07
01-26-2020 02:58
01-26-2020 02:58
Still an issue over 1 month later. This really isn't acceptable the breaking update should have been undone.
Best Answer01-26-2020 06:38
01-26-2020 06:38
When I reached out to customer service, they told me my phone is not compatible, sent me a list of compatible phones and told me to use a compatible device. Well I'm not buying a new phone...
Best Answer01-26-2020 07:08
01-26-2020 07:08
01-28-2020 04:49
01-28-2020 04:49
I wonder if there is a way to go back a version until they get the issue resolved? I only use one of the new features of the update anyway, which I can live without until the issues is resolved.
Best Answer01-28-2020 06:01
01-28-2020 06:01
I just dealt with FITBIT Chat - found out my phone was not compatible with FitBit - I have a newer phone than what is on their list. Here is the list they provided me. https://help.fitbit.com/articles/en_US/Help_article/2315
They suggested that I get a phone that is on this list - or wait to see if FitBit will provide an update to become compatible to my Moto Z4. I will wait!
Best Answer01-28-2020 15:13
01-28-2020 15:13
I have a compatible phone and still have this issue, so its probably not the phones fault.
Best Answer01-28-2020 15:24
01-28-2020 15:24
01-28-2020 20:29
01-28-2020 20:29
I have a compatible phone and OS and it’s happening on my brand new Versa 2. Makes the calories feature wildly inaccurate and useless. Fitbit, please fix!
Best Answer02-01-2020 05:01
02-01-2020 05:01
Best Answer02-01-2020 08:18
02-01-2020 08:18
I have everything up to date and this still does not work for me.
Best Answer02-05-2020 08:00
02-05-2020 08:00
Brian:
Almost fixed the issue.
There still seems to be some sort of rounding error, as though the weight I enter is manipulated and then unmanipulated. For example, the past 2 days, I have logged 241.2 and 238.4 pounds on my Versa 2 watch, and the app has recorded 241.1 and 238.3 lbs, respectively, and my Vesra 2 watch says I have 38.3 pounds to go. This is definitely an improvement, but their fix appears to be somewhat inelegant.
Jeff
Best Answer02-05-2020 08:23
02-05-2020 08:23
Ok, another update just pushed to me today and it looks like it fixed the logging issue. I guess i just had a delay in getting the update available a few days ago.
Best Answer04-22-2020 08:37 - edited 04-29-2020 01:11
I don't trust apps like fitbit, there is always some problem and it never shows the real results. You should go old school with that, just set a goal for yourself, exercise and use a scale to measure your progress. You can never go wrong with that. The only problem with scales is that some of them are measuring only in kilograms and i don't understand that and it's too much for me to convert it myself. When i moved to Europe everything was in kilograms and i had to use a converter that can quickly give me results for stuff like "150 lbs to kg" to really know my weight. I used it for everything and it is great, in a few milliseconds you get your results and you are good to go!
Best Answer04-22-2020 18:16
04-22-2020 18:16
06-01-2020 00:31
06-01-2020 00:31
This is so helpful thank you! It’s very frustrating that the weight I log on my watch is consistently 0.1lbs above what appears incorrectly on the app immediately after....
Best Answer10-11-2020 04:20
10-11-2020 04:20
I have exactly the same problem. But in reverse to the earlier post. I enter weight on versa watch (which it says is in kg), this gets taken as a value of lbs, and converted to kg! doesn't always do it wrong, just sometimes. So this morning I lost 39.3 kg of weight overnight!.
Support chat with Fitbit agent described the problem. Their answer? Well don't do it that way. Use the Fitbit app on the phone. I pointed out that hey have added the feature of entering data directly on the watch, which is convenient, but doesn't work properly. They just repeated - Don't use the watch, use the Fitbit app.
Completely ignored the fact that I'm raising a bug report with the watch software. No intention of addressing it, even though there are '00s of reports of similar problems. Then asked for a feedback report on my 'support experience' !!!!
Best Answer10-11-2020 04:24
10-11-2020 04:24
Hm. The support agent I spoke to today didn't even acknowledge there was a problem. Juts told me 'if it works via the app, then don't use the watch to enter values directly!. Didn't give any indication that they were aware of a problem, or work on a fix.
I asked, 'why add the feature to the watch of entering data, then not appear to try and fix it when problems are reported.' Very poor user support experience.
