04-15-2020
10:31
18:26
DavideFitbit
04-15-2020
10:31
18:26
DavideFitbit
Not sure why but since April 8th my Versa wont sync and update in the app. Anyone else experiencing this?
Moderator edit: format
05-03-2020 13:17
05-03-2020 13:17
I had no issues re-installing it after I did this, and it did disconnect again maybe a week later, but I did the same power-off, wait for the FitBit app to start searching for bluetooth, and then turning it back on and that was a couple of weeks ago (I think. Gosh, I've lost all sense of time with the Covid thing going on).
WiFi paired up perfectly both times.
05-03-2020 14:40
05-03-2020 14:40
I have tried every recommended remedy, nothing works. As soon as the device is on my wrist all connections are lost and nothing works. Support instructed me to do a factory reset which I did. Well it took 12 hours to set up the device again. Couldn’t find wifi, couldn’t find blue tooth, I don’t know how I found the patience to persevere with it. Finally I had the device paired, an update finally installed. Put it on and wham, all gone again.
So Support acknowledged that a factory reset did not work. Now they are assessing whether to offer me a replacement. Mine is 16 months old so I’m guessing that will be a “no”.
I wait a week between each answer from Support.
05-04-2020 14:23
05-04-2020 14:23
05-04-2020 16:13
05-04-2020 16:13
I did everything that I ha e read here and it still doesn’t work and this has been going on for about 21/2 months so what is the fix or isn’t there one
05-04-2020 21:52 - edited 05-04-2020 21:58
I've tried this method from Hdjdjsnsjxh and it can connect now.
05-04-2020 23:11
05-04-2020 23:11
For mine, it’s a no. Fitbit support cannot offer any further solution 😩
05-05-2020 02:46
05-05-2020 02:46
I contacted the Fitbit support and try another steps they shared which is forgetting / deleting all the bluetooth connection except the Versa2 on my android devices and so far the problem solved. I can sync my watch to the phone all the time now.
05-05-2020 02:56
05-05-2020 02:56
you’re lucky. Unfortunately didn’t work for me. Tried this several times weeks ago.
05-05-2020 05:21
05-05-2020 05:21
Sorry to hear that. Previosly i also have ionic which now in the land of the dead. Cant turn on anymore. I tried all the steps offered but also no hope.
