09-19-2019 16:14
09-19-2019 16:14
Hi,
I bought the Versa 2 yesterday and upon setting this up i can only quick reply to messenger notifications. I have my default messaging app set as text messages. When i get a text message the only two options i get is to open this on my phone or to clear it.
Is there something i can do to get this feature to work? I have an Oppo phone and Im in Australia, using Optus provider.
09-19-2019 16:53
09-19-2019 16:53
Don't know if you're already doing this, but here are the official instructions.
How do I use quick replies on my Fitbit device?
When you receive a notification from your phone, your device vibrates. To respond with a quick reply:
Best Answer09-19-2019 20:25
09-19-2019 20:25
09-21-2019 10:14
09-21-2019 10:14
Same problem here with text messages. I'm using Textra for SMS but I switched to the stock MESSAGES app that came with the phone and same result - YOU CANNOT REPLY!
This obviously is a bug and I really hope this is fixed soon!!! You think this would have been tested before releasing a new product!!! Somebody at Fitbit should have their A$$ handed to them for this blunder!!!
09-21-2019 11:17
09-21-2019 11:17
Issue resolved for me! I previously had the Fitbit app installed on my phone before I got the Versa 2.
This was the problem!! I uninstalled the app on the phone and reinstalled it. It asks for a bunch of permissions when you 1st open the app and now I can reply to my texts!!!
Hopefully this will solve some peoples issues if they were in the same situation I was in.
Good luck!
09-21-2019 11:33
09-21-2019 11:33
Issue resolved for me! I previously had the Fit bit app installed on my phone before I got the Versa 2.
Good luck!
03-11-2020 19:13
03-11-2020 19:13
It doesn't work for me either
Best Answer03-20-2020 15:28
03-20-2020 15:28
I don't have the reply option for only one person in my contacts lis . Any idea why this is?
Best Answer03-20-2020 16:54
03-20-2020 16:54
Still having the same problem not working
Best Answer03-20-2020 17:20
03-20-2020 17:20
You uninstalled the app and reinstalled it? Did you reboot your watch before you logged into the fresh install on yr phone? I notice every few weeks or less I have to restart my Versa 2.
Best Answer03-20-2020 17:25
03-20-2020 17:25
Are u using a phone with Android 10? The Fitbit app. Must be setup to run in the background and not be put to sleep - This is very important also.
Best Answer03-20-2020 17:29
03-20-2020 17:29
I figured out my problem. For the one contact my settings had somehow changed. I should be good now.
Best Answer03-21-2020 06:28
03-21-2020 06:28
Yes did both and nothing has worked
Best Answer05-26-2020 00:32
05-26-2020 00:32
I also have an oppo in Aus but I am with Vodafone. I have the option to reply on WhatsApp, even with my voice. But no option is given on my text msg to reply, not even the quick reply.
Best Answer04-01-2021 07:55
04-01-2021 07:55
I'm having the same issue. Just bought a Sense and really excited. I've been struggling with a Charge 3 where I cannot see the screen outside.
I've been onto FB for 2 hours today trying to find a solution. If anyone has any non patronising solutions it would be great!.
06-02-2021 15:57
06-02-2021 15:57
Has this issue been fixed yet for you? I cannot figure out how to get replies to work !!
Best Answer06-03-2021 12:37
06-03-2021 12:37
