12-31-2019 21:33
12-31-2019 21:33
I purchased a Versa 2 nearly two weeks ago, and the touch screen has been intermittently unresponsive, for longer and longer stretches of time. Now, it isn't responding at all, and has been like this most of the day.
I tried restarting the watch multiple times, syncing, unpairing, repairing, and nothing is working. The only thing I haven't tried yet was a factory reset, since I can't navigate into the menus to be able to attempt it.
I'm fairly confident that it isn't any kind of water damage, as the only water contact has been brief and nearly nonexistent while I was washing my hands or doing the dishes, and seeing all the other topics about it, I'm thinking this may be a hardware error.
If anyone else has any ideas as to what could be causing this, beyond hardware malfunctions, I'd greatly appreciate it.
12-31-2019 22:20
12-31-2019 22:20
Update: managed to get it to factory reset, and it didn't solve it. The problem of the touchscreen not responding is still ongoing.
Best Answer01-01-2020 05:42
01-01-2020 05:42
I have the same issue. Haven`t been able to use it for a month now.
They clame it is software issues, but i don`t think so.
01-02-2020 20:36
01-02-2020 20:36
I have the versa 2 as well have had it for a month now and have really over the last week or so have noticed that it isn't work properly and want respond to touch hasnt been hot or damaged this thing cost to much money to not work
01-03-2020 02:07
01-03-2020 02:07
Same issue here. Clock shows, but no swiping possible. Sometimes button is unresponsive too. This is getting progressively worse. Have tried restart, switch off - switch on, factory reset. No dice. Seems to hae started at the last update.
01-03-2020 02:09
01-03-2020 02:09
Best Answer01-03-2020 02:52
01-03-2020 02:52
Best Answer01-11-2020 09:52
01-11-2020 09:52
I went to the shop where i bought it and talked to them. Got a new watch, and this one works perfect for now. Hope it lasts 🙂
Best Answer03-18-2020 20:03
03-18-2020 20:03
Is your watch still working? They offered to send me a new one but Im scared it wont work.
03-18-2020 23:24
03-18-2020 23:24
Best Answer03-25-2020 19:01
03-25-2020 19:01
I agree. It bagan when I started to leave it on while I showered.
03-25-2020 19:23
03-25-2020 19:23
Best Answer04-08-2020 17:16
04-08-2020 17:16
I have a theory about these touch screen malfunctions but it's only a theory at this point. To see if your problem is consistent with what I've observed, take the watch off and put it in the charging cradle for at least 1 day. After the 24 hours have passed, try the touch screen on the watch; you don't even have to take it out of the cradle.
If the touch screen is responsive again, i.e. it swipes up, down, right and left it supports my theory and I'll give you a suggestion that might fix the problem. No cost or returning to fitbit.
04-18-2020 21:28
04-18-2020 21:28
Hi Thurman, what is your theory? This worked for me but then after wearing for 15 minutes, it stopped working again.
10-23-2020 04:41
10-23-2020 04:41
So, I did this and it is responsive on chargi g cradle.....but is there a fix? Support was ni help whatsoever.
Best Answer10-23-2020 04:47
10-23-2020 04:47
Did you ever get yours working?
Best Answer10-23-2020 05:40
10-23-2020 05:40
Best Answer10-23-2020 06:41
10-23-2020 06:41
My problems began when my Fitbit got wet but not immersed in water.
Best Answer10-23-2020 06:53
10-23-2020 06:53
I have the same problem out of the blue
Best Answer06-26-2021 19:59
06-26-2021 19:59
I have been using versa 2 for a couple of weeks and it seems to have some problem with its display. Whenever I bring it in water it just turns off and even if I turn on it back manually it does however it is unresponsive to touch. It all started after the last update
