12-29-2019
20:35
14:44
RicardoFitbit
12-29-2019
20:35
14:44
RicardoFitbit
I keep seeing a lot of users are struggling with this issue and don’t see any resolution aside from restarting it. My versa froze and I had to hold the side button multiple times to get it to finally reset. When it did reset, it still was frozen and would vibrate randomly and this has happened multiple times. It woke me up in the middle of the night vibrating and wouldn’t stop till I reset it a few times. This is getting quite annoying since it’s now interfering with my sleep, so what is the fix for this? Is FitBit working on a patch in the software or a permanent resolution because having to reset a watch every day because of this glitch isn’t acceptable. Especially when you’re wanting members to pay for premium when there’s a massive error occurring in the actual product.
Hello everyone, thanks for your participation in the Community. For all of you who are new to the Fitbit community, welcome.
Thanks to all for the efforts to resolve the issue, sharing the solutions and steps you've tried. I understand that this can be very frustrating, your feedback and comments are greatly appreciated. If you're experiencing this issue, please try the following steps:
1. Restart your watch: How do I restart my Fitbit device?
2. Connect your watch to the charging cable.
3. Make sure your watch is updated: How do I update my Fitbit device?
4. If the issue persists, remove your device from the Bluetooth settings of your phone.
5. Reboot your phone, open the Fitbit app, tap on your profile picture > Set Up a Device.
6. Choose your Fitbit from the list and follow the onscreen instructions.
If the issue persists, the best way to get help for this problem is to chat with our Support team online or give them a call. Click here to get connected.
I am going to close this thread, but if there is anything else we can help you with, do not hesitate to start a new topic.
Have a nice day.
14:43
09:23
01-03-2020
14:43
09:23
Hi @Mandabear424, welcome to the Community Forums! Sorry for the delayed reply.
Thanks for bringing this to my attention and for the troubleshooting steps that were tried prior to posting, I totally understand how frustrating this matter can be for you. To better assist you with this, can you please let me know when was the first time you experienced such inconvenience and how many times since then? If you haven't already done so, please try our factory reset procedure following the next steps:
Keep me posted. The feedback that was shared in your post is appreciated.
Best AnswerI tried the factory reset and now the touch screen isn’t even reacting, I contacted FitBit support and have a replacement on the way. I’m not hopeful this won’t happen again as it is a common issue being mentioned in these forums.
My versa 2 button quit working a few days ago. Now the screen froze when I tried to sync my earbuds.
the screen has a pic of a watch and a phone and says
source
output
audio output is
controlled by phone
holding the button doesn’t do anything.
I also am experiencing the same issues after only three months. The screen freezes, I restart the device and after a few swipes the screen freezes again.
I tried the factory reset which turned out to be a disaster since now my device is completely unresponsive.
04-10-2020 07:25 - last edited on 08-13-2020 20:14 by LiliyaFitbit
I sent mine back and they sent a new one.
Best AnswerThanks for your reply. I’ll look it it
Best AnswerI have been having this issue for well over a month. Apparently I did the factory reset w/o even knowing it but problem still persists. The app on the phone is getting the info but the watch itself is very unresponsive.
That is exactly what I am experiencing. I have not been able to find a solution anywhere. I think the only recourse is to contact Customer Support but given what’s going on with the pandemic it’s low on my priority list.
Hi I was able to get my Versa2 working again;
1. Make sure your device is fully charged
2. In the Fitbit app on your phone if the Versa2 is still listed within the app, remove it.
3. In the Bluetooth setting on your phone there should be a list of items that are or were connected. If the Versa2 is there, tap on it and hit forget this device
4 Within the Fitbit app hit +setup device
this should restart the process just make sure your Bluetooth is on and the watch is changed. Hope this works for you Good Luck!
Best AnswerDid all that, now the issue is when trying to pair 4 numbers are supposed to show up on the screen but the screen is not responding so I'm running out if luck I'm. afraid. Now it's totally useless. And just an aside, the watch was randomly vibrating but I had no notifications set up except reminder 250 steps every hour which vibrated at 10 mins. Before the hour.
Thanks for the help
Your welcome. Sorry to hear it didn’t work. It took me several attempts before the four numbers appeared on the watch.
Best AnswerI've had my versa 2 since Christmas with no problems in recent weeks my watch has started to freeze up. I have read the post on here to reset it. So I have tied holding the button till the logo came up and then again after two seconds. The problem still is constantly happening. I need help with more information on what to do.
Best AnswerMine was not necessarily freezing, it just was not displaying anything on the watch.
I actually just received a replacement from Fitbit.
Best AnswerMy Versa 2 is frozen with the Fitbit logo on the face. It is unresponsive when I press the restart button.
Best AnswerMy Versa2 also froze. I was able to resolve the issue by eventually going to settings>about >factory reset. It took several attempts.
Then charge the watch. In the Fitbit app on my phone, I tapped on Versa2 scrolled down and tapped on ‘forget this Versa2’
Then I started the setup process again (+setup a device)
make sure your Bluetooth in on in your phone settings. You should receive a four digit code.
enter it to redo the setup
Once my watch was functional again I found that keeping it in the always on mode kept it from freezing.
This was a very frustrating process!! I hope it helps you!
Best AnswerMy watch does the same thing. Factory reset did nothing. And customer service has been terrible. 2.5 hours on hold without getting to talk to anyone. Tried twitter DM and I get a response once every 9 hours or so.
Best AnswerI received a response from Facebook messenger within an hour and they started a ticket. Had a new watch (only the watch) within a week,
