08-24-2021
23:14
04:15
08-24-2021
23:14
04:15
Hi
my versa 2 has seemed to of frozen
firstly it started jumping between screens now it’s frozen
i have tried all resets etc but it’s still the same any idea or does it need to go to Fitbit heaven
08-25-2021 04:17
08-25-2021 04:17
Hi there, @Sch32. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Since none of the steps you tried have worked, I recommend doing a factory reset:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Hope that helps.
Best Answer08-25-2021 04:17
08-25-2021 04:17
Hope that helps.
Best Answer08-29-2021 06:02
08-29-2021 06:02
Hi
still having problems with Versa2 touch screen does not work so guessing it’s packed in
thank you for help
simon
Best Answer08-29-2021 16:46
08-29-2021 16:46
Mine was doing the same thing for a few days. And yesterday it went completely black and won't turn on. When I try to reset it the firbit logo pops up for a sec then nothing.
Best Answer08-30-2021 16:51 - edited 08-19-2023 07:25
@Sch32 @rylynn712 If the steps I recommended here don't do the trick, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
