01-29-2025
22:35
08:55
FatimaFitbit
01-29-2025
22:35
08:55
FatimaFitbit
Last week I did the mandatory firmware update to version 36.128.6.21.
Before doing the update my battery would last about 5 -6 days (depending on how much exercise I did).
Now since doing the update it lasts less than a day. That's with everything turned off too (eg. Notifications, snore detection, vibrations etc) .
Makes it pretty much useless as I don't get accurate sleep data and when I want to use it for a run I have to wait for it to charge. Anyone else had the same issue?
02-01-2025 08:54
02-01-2025 08:54
Hi there @SunsetRunner! It's great to hear from you!
Thank you so much for reporting this situation and for all your efforts.
I suggest you read this article: Sense and Versa 3 Battery Performance Program The firmware update improves the stability of the battery performance and reduces the risk of the battery overheating. Affected devices will experience a reduction in battery capacity. You can submit a request to find out if your device is impacted here.
02-04-2025 23:09
02-04-2025 23:09
My Sense had a mandatory update yesterday and the battery was charged to 100% at lunch and I just received a notice that my battery was already low. The firmware update has caused an extreme battery reduction. It seems to me that the battery should not overheat when it was lasting almost a full week on one charge, where now it burns through a full battery charge in a day. Can you explain this further?
02-05-2025 05:55
02-05-2025 05:55
I just updated mine Versa 3 for what they said was that battery overheating issue. A problem I never had and now my batter on my versa doesn't even last half a day when before I could get at least 2 or more days in a full charge. Is there a way to recover that capacity? If not, this makes my watch useless and will have to look at alternative watches to gain what I need.
02-07-2025 16:51
02-07-2025 16:51
This most recent update has basically made the watch unable. Maybe that we the whole intent. $50 appeasement for a $200 watch seems like a pretty poor solution. You should have offered a replacement watch at a severely discounted price. Seems like the time to buy a different brand of watch.
02-08-2025 06:39
02-08-2025 06:39
I did the update also. My battery symbol stays at 100%. I charged it 2 days ago. Something is definitely fishy!!
02-08-2025 08:51
02-08-2025 08:51
I had to charge mine twice in one day and it cannot even make it through the night now. It is unusable.
02-20-2025 17:49
02-20-2025 17:49
The past two weeks I've had to recharge a lot more frequently, and I've been having constant disconnects from my phone. I rarely get any of my notifications after updating, and when I do it's nearly 100 in one go.
02-21-2025 10:17
02-21-2025 10:17
Hi there everyone!
Thank you all for letting us know that your Versa 3's are impacted too and for all your efforts. I'm really sorry to hear that after the firmware update the batteries of your devices are draining too fast.
You can submit a request to find out if your devices are impacted here. I suggest you try the tips from this article too: Can I extend my Fitbit device's battery life?
If the situation continues, please try to contact customer support: Contact Us
02-22-2025 02:04
02-22-2025 02:04
Can you please offer a solution that actually works? I have to charge my battery twice a day ever since your update.
02-22-2025 07:07
02-22-2025 07:07
Hi there! A warm welcome to the Fitbit Community!
I suggest you submit a request to find out if your devices are impacted here and please try to contact customer support: Contact Us.
Best Answer02-25-2025 14:35
02-25-2025 14:35
Hi please to reset the firmware or give us the option to. My Versa 3 has gone from only needing to be charged every 6 to 7 days to everyday and this is unacceptable. It seems like multiple mods have tried to respond to this without any actual change and this is frustrating to say the least.
My battery never overheated prior and now it's just useless.
02-25-2025 22:53
02-25-2025 22:53
Same! The update was basically a trap to make fitbit useless so we buy their newer models- except I'm never doing that!
There was nothing wrong with my fitbit's battery, easily would last 3-4days single charge vs now less that 7 hours my watch is dead.
03-03-2025 10:20
03-03-2025 10:20
03-05-2025 15:40
03-05-2025 15:40
Best Answer03-05-2025 16:29
03-05-2025 16:29
I’ve had the same but I’ve also had an issue where my watch goes off alerting me I have 10,000 steps then once my app syncs I all of a sudden have 8k?!?! What is going on?
03-05-2025 16:39
03-05-2025 16:39
Best Answer03-05-2025 16:42
03-05-2025 16:42
03-06-2025 11:45
03-06-2025 11:45
I am having the same issue: 4 to 5 days between charging before the update to having to charge my fitbit Versa 3 daily after the update. Like others have stated, I have never any issue with my fitbit getting hot. This seems like a ploy to get people to buy a new fitbit tracker. It might not be, but that is how it seems.
03-06-2025
15:26
16:59
ManuFitbit
03-06-2025
15:26
16:59
ManuFitbit
Exactly
I did the update it totally screwdriver up my watch, screen goes black after a couple hours
