02-09-2022
09:12
20:28
02-09-2022
09:12
20:28
I had an inspire and bought the Versa 3 but I have to charge it daily or every 36 hours. I contacted support but they were useless and don’t understand the issue. Obviously reading a script, any ideas on how I can get the 6+ days advertised?
02-10-2022 05:07 - edited 12-13-2023 03:43
Hi there, @FrannieB1111. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Totally agree with @JohnnyRow, specially if you've noticed the battery goes down during your sleep. You can compare your Versa 3's battery life afterwards and see if that makes any difference.
However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
02-09-2022 09:14
02-09-2022 09:14
If you have Snore Detect turned on, that takes a big battery hit.
Hope that helps.
03-22-2022 05:12
03-22-2022 05:12
Hi... I feel your pain with this as I've had the same issue. I previously had a Versa and Versa 2 and everything was fine. My partner bought me a Versa 3 about 8 weeks ago. The battery drained in about 2 and a half days even though I turn it off overnight. I spoke to customer services who are the worst I've ever encountered. They have no emotions and i actually thought they were robots. They finally agreed to change it due to the battery issue so sent me a new pebble (took 4 weeks to arrive). The replacement does exactly the same and drains 20% of the battery overnight even when turned off. I spoke to customer services again who tried to say the tolerances were normal. I eventually spoke to a supervisor after 3 calls to the centre. The supervisor was exactly the same scripted and sounding like a robot. She told me not to use the GPS as this would drain the battery. The only reason I changed to a 3 was for the built in GPS, so why would I not use it. They would not entertain a refund and have sent me another replacement pebble that arrived the following day (today). If the battery drain on this is the same I will lose my patience as this is REALLY unacceptable.
03-22-2022 07:46
03-22-2022 07:46
@KWJames - the short battery life is unlikely to be the watch, but more the features that are used all the time.
Snore detection and SpO2 can use upto 4 days of the 6 days battery autonomy.
See the issues How to resolve the Major issues causing short battery life.
03-24-2022 07:20
03-24-2022 07:20
Mi e was working 5-6 days of battery life. Now 18 hours. I am so disappointed this is my fourth Fitbit they seem to last less than two years. Time to move on to a different company
04-05-2022 01:47
04-05-2022 01:47
Hi
Thanks for your reply.
I turn it off every night and when I turn it back on in the morning its lost between 15 - 20% of battery. I had a Versa and Versa 2 which were both great but I soooo disappointed with this. I also struggle in the morning to turn it on and takes a few attempts. I'm on my third replacement now and the latest is just as bad as the others.
04-05-2022 03:39
04-05-2022 03:49
04-05-2022 03:49
So annoying. It bugs me. I am lazy with charging so 6 days was awesome 20 hours not so much
04-05-2022 04:10
04-05-2022 04:10
Hi @SunsetRunner - please elaborate what changed between 6 days charging and 20 hours.
Also can you indicate how the charging is measured.
To help you may want to try the SimpleClockPro watch face from the Gallery which logs and measures charging and discharging so you will have a precise point of reference when making changes.
It also predicts by when the watch should be charged so you will know if it is very different that there is a charging issue. There may be other tools that may help.
The main issues to try are listed in the How to resolve the Major issues causing short battery life.
and if you detect a charging issue How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
04-05-2022 04:24
04-05-2022 04:24
One of the Fitbit experts looked at my watch and yes it is draining. I changed the face etc.
it went from 6 days to 2 and a bit days now I get maybe 20 hours.
04-05-2022 04:35
04-05-2022 04:35
@SunsetRunner- things get updated in background too. Make sure Snore detection is off and you don't use music of GPS [exercises]
What you can then try is:
Then see how long the battery lasts without turning on the Bluetooth or syncing. You won't get any notifications during this test.
The objective is to see if it's an issue caused by the app and syncing or if it is a watch problem or a settings issue.
04-05-2022 04:39
04-05-2022 04:39
I never use snore detect or music
I will try what you said. But to me one day it is fine the next day it is not. Means the battery is dying.
Why buy a good watch if you cannot use some of the fun settings?
i am at work now so I don’t have wifi.
katie
04-05-2022 04:46
04-05-2022 04:46
@SunsetRunner - thanks, it doesn't mean you can't use features, it's just a matter of locating the one that's causing a problem.
Generally batteries don't die like that and it is far more likely to be an errant usage as the cause.
Once resolved it should be normal again, with any luck!
One question why do you need WiFi? Do you mean the charger?
