08-03-2022
19:03
17:37
08-03-2022
19:03
17:37
I have paired Versa 3. All permissions given. Battery optimisation is off. Tried clearing cache, force stop, re-installing app. I have factory reset Versa 3. Nothing works.
Versa 3 is paired but cannot sync. It just tries over and over and gets nowhere. Please help.
Update: Trying to sync
Moderator Edit: Clarified subject & Merged posts
08-05-2022 08:25 - edited 08-05-2022 09:31
Restarting a phone or tracker does a soft(ware) restart. This may not fix a hardware issue and a shutdown or hard restart will be needed.
If you haven't done so yet, try a hard(ware) restart by shutting off the phone and tracker.
08-03-2022
23:02
04:21
08-03-2022
23:02
04:21
I'm having the same issue. I've just returned from holiday and ithe time is still showing two hours ahead.
I've tried shutdown, uninstalling the app and reinstalling but no change.
Update: Try going into the app from the PlayStore. Once I did this it synched straightaway.
08-04-2022 02:29
08-04-2022 02:29
Hi @originaldigga - did you restart the phone?
08-04-2022 02:31 - edited 08-04-2022 02:31
Hi @SunsetRunner - normally to fix the time zone bug, click profile photo, App settings and disable the automatic time zone and location and enter the time zone manually, then sync.
After that you can put the settings back as they were.
08-04-2022 02:38
08-04-2022 02:38
08-04-2022 02:42
08-04-2022 02:42
@SunsetRunner- appreciate the feedback, bad syncing would be an issue. Thanks
08-04-2022 03:27
08-04-2022 03:27
I have restarted the phone and the versa a number of times.
08-04-2022 03:42
08-04-2022 03:42
@originaldigga - have you had a chat Via the Fitbit App, click profile photo, Help & support, Contact Customer support, see what they have to say.
08-04-2022 04:29
08-04-2022 04:29
Hi there, @originaldigga. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out and the image provided.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
If your phone does meet the requirements, see Why won't my Fitbit device sync?
On a side note, please know that since you're an Android user you can't use MobileTrack in addition to a Fitbit device. For more information about MobileTrack, see How do I use Fitbit MobileTrack?
If you have MobileTrack linked to your Fitbit account you'll need to remove it in order to set up the Fitbit device and get back on track. For instructions, see How do I set up my Fitbit device?
If none of the above works, as @Guy_ has recommended, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hi there, @SunsetRunner. Welcome on board! I'm glad to hear you managed to solve the issue with your Fitbit device. I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
See you around.
08-04-2022 04:44
08-04-2022 04:44
I am using Pixel 6 Pro, it's not listed as an unsupported device. MobileTrack is not connected to my app. I tried chatting with customer service but it says that the office is closed. I tried looking for the office hours but I could not find them on the website.Customer Service not available
08-04-2022 04:48
08-04-2022 04:48
@originaldigga- try chat not call.
08-04-2022 04:56
08-04-2022 04:56
How do you do that Guy?
08-04-2022 05:01
08-04-2022 05:01
@originaldigga- chat Via the Fitbit App, click profile photo, Help & support, Contact Customer support and choose chat.
08-04-2022 05:14 - edited 08-04-2022 05:15
This is the method I am using, but I do not see a chat option.
08-04-2022 05:31
08-04-2022 05:31
@originaldigga- this is what appears, if it doesn't for you may be it is something to do with your country or settings.
Check this link in case you have a security setting which may disable chat No internet connection
08-04-2022 05:37
08-04-2022 05:37
I'm not using a adblocker or VPN but I am on android 13 beta. It's the only thing left I can think of.
I might roll back to android 12 and see if that fixes it. If not, maybe it's a hardware issue and I'll look into replacement. I've only had the versa for 5 weeks.
08-04-2022 06:00
08-04-2022 06:00
@originaldigga- and Private DNS? is the most likely issue.
08-04-2022 06:12
08-04-2022 06:12
I haven't set up private DNS but I checked my settings. There is no private DNS listed, however the phone is set to automatic rather than off.
Not sure if that will make a difference? I'll try changing the mode to 'off' and see if it works.
08-05-2022 01:37
08-05-2022 01:37
Well I bit the bullet and rolled back Android 13 Beta to 12. This fixed all my pairing issues, and tracking working well! 😊
Still not getting notifications on the wrist however and the Versa controls won't pair 🤔 Halfway there I guess.
08-05-2022 01:45
08-05-2022 01:45
@originaldigga - thanks for the update. You may not get notifications due to a bug in the latest version of the Fitbit App, so no point chasing that one.
