10-26-2019 18:55 - last edited on 10-27-2019 14:30 by LiliyaFitbit
I've had my versa lite for 2 months, had no issues with it until the firmware update. Now I can't get it to pair with my Bluetooth to even do the update. Fitbit sent me a new one after assuring me that my phone is compatible (Lg G6). And it is not. I can't even get my phone to see it via Bluetooth. It did pair the very first time i set it up, then it would never sync correctly. I've done every trouble shoot tip they give with absolutely no luck. Almost $200 for 2 months of use. Great birthday present that now is junk. Totally disappointed, will NEVER recommend anyone to get one.
Best Answer03-09-2020 16:45
03-09-2020 16:45
Best Answer03-14-2020 13:07
03-14-2020 13:07
You may want to ditch the versa lite and get a versa 2. The lite is ok once you get it setup but it was a pain for me orginally. I just got a Versa 2 and it was a breeze to setup because it also has wifi. But I am trying to give my old one to my daughter and it isn't updating. Keeps failing or just getting stuck. I wish I hadn't tried a factory reset
03-28-2020 20:02
03-28-2020 20:02
I've troubleshooted my versa lite for 2 days. Today alone it's been plugged in with my phone next to it for 6 hours,same results update failed AND a frozen screen on the versa lite. I've only had this since Christmas, this is ridiculous.
04-05-2020 22:14
04-05-2020 22:14
I’m so frustrated and I feel like my versa lite is defective. It worked well for 1 day. 1! It stopped registering my sleep, and I decided to do an update and well, I’ve been trying allllll day. It’s not properly syncing and I’m not at all satisfied. I have an iPhone. I need some assistance. I’ve tried everything. Help!!!
Best Answer04-07-2020 11:55
04-07-2020 11:55
I'm having the same problem as many others on this board. I've tried EVERYTHING. After troubleshooting efforts failed me repeatedly, I called to find out that I can use a computer with Windows to install the firmware/update... but I don't have a computer with Windows. I have an iPhone X and a Mac. After this not-super-helpful phone call, I started from Square One in hopes that something would be different, and when it wasn't, I switched to my work phone (another iPhone). No luck. Then --and this is embarrassing-- I BOUGHT A NEW Versa Lite. (I really liked it for the two months that it worked.) Aaaaand I'm having the same issues with the brand new one. So I've purchased two of these devices and now have two watches that don't work. I do not have time or patience left to deal with this. What's next?
04-10-2020 09:50
04-10-2020 09:50
Contacted Customer Support via chat. Now I have more errors than I had originally. What is "tile migration error"? Anyone know?
Best Answer04-11-2020 06:25
04-11-2020 06:25
I have found this myself 😞 I was bought a versa lite for mothers day and am yet to be able to use it after my 2nd one as neither watch will work. I was sent a replacement from fitbit after 3 veeeeery lengthy phonecalls and still the replacement directly from them isnt working. So disappointed as I actually love fitbit, but will now be switching to Garmin.
Best Answer04-14-2020 08:34
04-14-2020 08:34
Hi, I’ve had my Fitbit Versa Lite for maybe 2 months. It stopped giving me text and phone notifications, so I called Fitbit helpline. They tried troubleshooting and taking me through several steps to correct but to no avail. So they sent it to their engineering dept and said they’d be contacting me, but couldn’t say when. Really?? So I decided to return my Fitbit back to factory settings. I removed it from my Bluetooth, deleted my Fitbit app, and decided to start all over as if I just received it. Perfect idea, I thought! I restart my phone, turn on Bluetooth, download the Fitbit app. I turn on the Versa Lite and follow the prompts and input the code given. Then it says my Versa Lite needs to be updated, so I click enable update. It’s connected to Bluetooth, but doesn’t have the little blue circle with the i, next to it yet. It takes FOREVER, and then fails. I’ve tried this three times and it continues to fail. It’s my opinion that Fitbit has a firmware issue and won’t address it. This many people SHOULD NOT be having problems updating their Fitbits! Either fix it or take the Fitbits back. They’re too new to be having this issue. And they’ll continue to have it with every update. However, it doesn’t even matter if you can’t get past the first one! VERY VERY DISAPPOINTED. I WILL NOT RECOMMEND EITHER!
Best Answer04-14-2020 09:41
04-14-2020 09:41
Hi, would you please give the detailed steps you used to do this. Like what to click on, where on the computer screen to look, etc., or is it pretty self explanatory? Thanks so much.
Best Answer04-14-2020 09:57
04-14-2020 09:57
So I plugged it into my laptop. What am I looking for now as nothing is popping up on the screen. It just says my Versa Lite has been added. To what? Where do I go to do the update?
Best Answer04-14-2020 10:27
04-23-2020 10:34
04-23-2020 10:34
Ugh this is happening to me again! I had this issue late December, after ten days I received a replacement versa lite. And now it’s done it again. Can’t complete the update so now I have a completely non functioning device. I’m so disappointed and frustrated.
Best Answer04-23-2020 10:45
04-23-2020 10:45
Best Answer04-23-2020 11:16
04-23-2020 11:16
Best Answer04-27-2020 13:23
04-27-2020 13:23
Hello everyone, thanks for your participation in the Community. I am sorry for the delayed reply.
I appreciate the time that each of you took to share the details of the issue, the troubleshooting done and your experience.
We’re excited to announce the release of Fitbit OS 4.1.2 exclusive to Versa and Versa Lite, which addresses and solves the firmware update issue. Please check this link for more information.
If you have any questions, feel free to let me know.
Best Answer05-09-2020 03:12 - last edited on 05-10-2020 12:20 by LiliyaFitbit
I have exactly the same issues , my versa lite has stopped working after 5 months ,tried everything suggested without joy , support sent me a replacement pebble and it's stuck on update constantly it gets almost all the way then stops and fails , I've tried it on 2 different Android phones , my iPad and my windows pc via USB and nothing works ???? I've wasted countless hours trying to get the thing to update without success so now I have 2 useless versa lite pebbles and have had to go back to using my older Huawei band 2 ( which works perfectly !!) This just isn't acceptable.
Moderator edit: content
05-09-2020 06:03
05-09-2020 06:03
05-10-2020 12:37
05-10-2020 12:37
Welcome to the Fitbit Community, @Leedsboi. It's nice to see you around, @Ramtruck.
@Leedsboi thank you for joining the thread and sharing your experience. I am sorry your replacement Versa Lite is stuck on update, I totally understand how you are feeling and I am here to help. I appreciate your troubleshooting efforts and would like to confirm if you've followed the steps from this help article: Why can't I update my Fitbit device?
@Ramtruck thank you for your feedback. Our team is always working on improving our devices and user experiences, and your comments are always welcome. Upon checking with our Support team, I was told that you have already contacted them and that they were able to help you. Thank you for your time and efforts.
Looking forward to hearing back from you.
Best Answer05-10-2020 12:49
05-10-2020 12:49
05-10-2020 18:17 - edited 05-10-2020 18:18
Hi @Leedsboi, thank you for your reply.
I am glad to hear you were able to update your watch. Thank you for your time and efforts. I understand how frustrating this is for you and appreciate your feedback since this helps us to keep improving. I hope you continue enjoying the Fitbit experience and working on your goals.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members.
Keep on visiting the forums. Let me know if you have any questions.
